What is the difference(if any) between the western and eastern Dish Network arcs and their respective Dish 1000.2 and 1000.4 dishes.
Western Arc has newer more powerful satellites and Eastern arc has hand me down satellites with weaker signals. Weaker signal strength more rain fade.
How do you know whether you should be EA or WA? I am in Grand Forks ND, 58201 and put up the 1000.2 pointed at 110/119/129 and have a great signal. Every time I call Dish on something unrelated they keep telling me I need a new dish installed.
For me in MN the experience was opposite on both of these points. The southeast look angle seems to have less rain fade for me even though my signal starts off 10-15 points lower on 72/77 compared to 110/119. I also found that with the elevation screw and azimuth cam on the 1000.4 dish it was significantly easier to peak than pretty much any other dish I've worked with. (albeit I haven't worked with that many)Weaker signal strength more rain fade. Eastern arc was a pain in the ass to peak and achieve a good signal in south east Texas where I am and western arc is easier to peak.
your core is WA.so if i am looking at 110/119/61.5 what am i on.EA or WA.
When you consider rain fade I'd take a look at local weather patterns.
My Eastern Arc 1K4 setup has had far less rain fade then my previous 1K2 Western Arc dish even with the weaker signal.
Here in Northern Indiana we get heavy lake effect precipitation off of lake Michigan which would take out my 1K2 western arc dish all the time. Sometimes for an extended period as the lake conjures up more rain. The eastern look angles weather the storm much better with only a few picture breakups this summer and no total loss of signal.
As usual , your mileage and or geographical region will vary. IN my area of Texas we get signals in the high 30s and low 40s on 72.7, the main sat for programming. I could get in the 50s on 77 sat but it would always show in my system info screen as yellowed and it would show that it was losing signal locks several times a day. Like I said I will revisit the eastern arc dish , I have installed next to my dish 1000.2 sat dish , next year once new sats go up and the signal strength goes up. I really want to use it since to me the pq is better on sd channels on eastern arc compared to western arc. But in southeast Texas we can get quite a lot of rain , hurricanes excluded, and rain fade would kill me on eastern arc with the low signals I get today.
Limited time offer
