12/9/2009 2:24pm - Uplink Activity Report - 95 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 12/9/2009 2:24pm - 95 changes
Uplink Comparison Range: 12/09/2009 02:04P - 12/09/2009 02:23P
Channel Additions:
269 - MUN2 [MPEG2 SD] added to EchoStar11 110W TP 09 ConUS beam (NA)
269 - MUN2 [MPEG4 SD] added to EchoStar8 77W TP 29 ConUS beam (NA)
590 - MAKTV [MPEG2 SD] added to Anik F3 118.7W TP 24 ConUS beam (NA)
591 - LAMNR [MPEG2 SD] added to Anik F3 118.7W TP 07 ConUS beam (NA)
592 - ZHIVI [MPEG2 SD] added to Anik F3 118.7W TP 03 ConUS beam (NA)
593 - RLIFE [MPEG2 SD] added to Anik F3 118.7W TP 01 ConUS beam (NA)
4300 - TENIS [MPEG4 HD] added to EchoStar10 110W TP 29 Spotbeam 46/47 (NA)
4340 - GREEN [MPEG4 HD] added to EchoStar10 110W TP 27 Spotbeam 46/47 (NA)
4344 - MSNBC [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 1 (NA)
4361 - TENIS [MPEG4 HD] added to EchoStar10 110W TP 29 Spotbeam 46/47 (NA)
4403 - GREEN [MPEG4 HD] added to EchoStar10 110W TP 27 Spotbeam 46/47 (NA)
4408 - MSNBC [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 55 (NA)
5498 - MSNBC [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 1 (NA)
5498 - MSNBC [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 55 (NA)
5535(215) - TRV [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 55 (A) (H)
5537(214) - TWC [MPEG4 HD] added to Ciel-2 129W TP 02 Spotbeam 55 (A) (H)
5539(208) - CNBC [MPEG4 HD] added to Ciel-2 129W TP 14 Spotbeam 55 (A) (H)
5541(182) - DISC [MPEG4 HD] added to Ciel-2 129W TP 02 Spotbeam 55 (A) (H)
5543(183) - TLC [MPEG4 HD] added to Ciel-2 129W TP 02 Spotbeam 55 (A) (H)
5545(303) - HBO-W [MPEG4 HD] added to Ciel-2 129W TP 14 Spotbeam 55 (A) (H)
5547(108) - LIFE [MPEG4 HD] added to Ciel-2 129W TP 02 Spotbeam 55 (A) (H)
5549(166) - CMT [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 55 (A) (H)
5551(200) - CNN [MPEG4 HD] added to Ciel-2 129W TP 04 Spotbeam 55 (A) (H)
5555(139) - TBS [MPEG4 HD] added to Ciel-2 129W TP 04 Spotbeam 55 (A) (H)
5557(180) - ABCFM [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 55 (A) (H)
5559(176) - TOON [MPEG4 HD] added to Ciel-2 129W TP 04 Spotbeam 55 (A) (H)
5598 - GREEN [MPEG4 HD] added to EchoStar10 110W TP 27 Spotbeam 46/47 (NA)
5600 - TENIS [MPEG4 HD] added to EchoStar10 110W TP 29 Spotbeam 46/47 (NA)
9610 - TRIGT [MPEG4 SD] added to Anik F3 118.7W TP 13 ConUS beam (NA)
Channel Removals:
5554 - ESNWS (A) (H) removed from EchoStar11 110W TP 06 ConUS beam
5574 - SPIKE (A) (H) removed from EchoStar11 110W TP 06 ConUS beam
5580 - SYFY (A) (H) removed from EchoStar11 110W TP 06 ConUS beam
5582 - ESPN (A) (H) removed from EchoStar11 110W TP 06 ConUS beam
5590 - ESPN2 (A) (H) removed from EchoStar11 110W TP 06 ConUS beam
5596 - FX (A) (H) removed from EchoStar11 110W TP 06 ConUS beam
9575 - VERIA (A) removed from EchoStar11 110W TP 21 ConUS beam
9575 - VERIA (A) removed from EchoStar3 61.5W TP 16 ConUS beam
36850 - DNL8 (A) removed from Ciel-2 129W TP 21 ConUS beam
Channel Moves:
5536 - TRV [MPEG4 HD] moved from Ciel-2 129W TP 06 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5538 - TWC [MPEG4 HD] moved from Ciel-2 129W TP 02 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5540 - CNBC [MPEG4 HD] moved from Ciel-2 129W TP 14 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5542 - DISC [MPEG4 HD] moved from Ciel-2 129W TP 02 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5544 - TLC [MPEG4 HD] moved from Ciel-2 129W TP 02 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5546 - HBO-W [MPEG4 HD] moved from Ciel-2 129W TP 14 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5548 - LIFE [MPEG4 HD] moved from Ciel-2 129W TP 02 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5550 - CMT [MPEG4 HD] moved from Ciel-2 129W TP 06 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5552 - CNN [MPEG4 HD] moved from Ciel-2 129W TP 04 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5556 - TBS [MPEG4 HD] moved from Ciel-2 129W TP 04 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5558 - ABCFM [MPEG4 HD] moved from Ciel-2 129W TP 06 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
5560 - TOON [MPEG4 HD] moved from Ciel-2 129W TP 04 Spotbeam 55 to EchoStar11 110W TP 06 ConUS beam (A) (H)
36850 - DNL8 [143] moved from EchoStar11 110W TP 21 ConUS beam to EchoStar8 77W TP 21 ConUS beam (A)
Channel Package Flag Changes:
9317(51) - WAGV [MPEG2 SD] - EchoStar10 110W TP 12 Spotbeam 10 changed to Available (H)(Harlan, KY-N/A)
9317(51) - WAGV [MPEG4 SD] - Echostar12 61.5W TP 07 Spotbeam 6 changed to Available (H)(Harlan, KY-N/A)
153 - OTDCH [MPEG2 SD] - EchoStar7 119W TP 20 ConUS beam changed package flags (A)
153 - OTDCH [MPEG4 SD] - Nimiq5 72.7W TP 05 ConUS beam changed package flags (A)
617 - ZCINE [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
640 - TVJPN [MPEG2 SD] - EchoStar3 61.5W TP 18 ConUS beam changed package flags (A)
641 - TVJPN [MPEG2 SD] - EchoStar7 119W TP 09 Spotbeam 1 changed to shown in non-sub's guides (A)
675 - TVJPN [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
727 - VIDIT [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
730 - RAINW [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
790 - ZCINE [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed package flags (A)
8398(16) - KOSAD [MPEG2 SD] - EchoStar10 110W TP 12 Spotbeam 27 changed to Available (H)
Channel Mapdown Changes:
5507 - NFL EchoStar10 110W TP 12 Spotbeam 46/47 mapdown of 154 added (A) (H)
5510 - HDNET EchoStar11 110W TP 07 ConUS beam mapdown of 362 added (A) (H)
5515 - HBO-E EchoStar11 110W TP 13 ConUS beam mapdown of 300 added (A) (H)
5516 - SHO-E EchoStar11 110W TP 13 ConUS beam mapdown of 318 added (A) (H)
5517 - VS. EchoStar10 110W TP 29 Spotbeam 46/47 mapdown of 151 added (A) (H)
5518 - NTGEO EchoStar10 110W TP 27 Spotbeam 46/47 mapdown of 186 added (A) (H)
5520 - APL EchoStar10 110W TP 29 Spotbeam 46/47 mapdown of 184 added (A) (H)
5521 - BRAVO EchoStar10 110W TP 27 Spotbeam 46/47 mapdown of 129 added (A) (H)
5522 - CBS C EchoStar10 110W TP 12 Spotbeam 46/47 mapdown of 152 added (A) (H)
5524 - DISXD EchoStar10 110W TP 12 Spotbeam 46/47 mapdown of 174 added (A) (H)
5525 - BIO EchoStar10 110W TP 29 Spotbeam 46/47 mapdown of 119 added (A) (H)
5527 - FOXB EchoStar10 110W TP 27 Spotbeam 46/47 mapdown of 206 added (A) (H)
5528 - GOLF EchoStar10 110W TP 27 Spotbeam 46/47 mapdown of 401 added (A) (H)
5530 - HMC EchoStar10 110W TP 12 Spotbeam 46/47 mapdown of 187 added (A) (H)
5531 - LMN EchoStar10 110W TP 27 Spotbeam 46/47 mapdown of 109 added (A) (H)
5532 - SCI EchoStar10 110W TP 29 Spotbeam 46/47 mapdown of 193 added (A) (H)
5533 - WGN EchoStar10 110W TP 12 Spotbeam 46/47 mapdown of 239 added (A) (H)
5534 - BET EchoStar10 110W TP 12 Spotbeam 46/47 mapdown of 124 added (A) (H)
5535 - TRV Ciel-2 129W TP 12 Spotbeam 1 mapdown of 215 added (A) (H)
5537 - TWC Ciel-2 129W TP 05 Spotbeam 1 mapdown of 214 added (A) (H)
5539 - CNBC Ciel-2 129W TP 10 Spotbeam 1 mapdown of 208 added (A) (H)
5541 - DISC Ciel-2 129W TP 05 Spotbeam 1 mapdown of 182 added (A) (H)
5543 - TLC Ciel-2 129W TP 05 Spotbeam 1 mapdown of 183 added (A) (H)
5545 - HBO-W Ciel-2 129W TP 10 Spotbeam 1 mapdown of 303 added (A) (H)
5547 - LIFE Ciel-2 129W TP 05 Spotbeam 1 mapdown of 108 added (A) (H)
5549 - CMT Ciel-2 129W TP 12 Spotbeam 1 mapdown of 166 added (A) (H)
5551 - CNN Ciel-2 129W TP 07 Spotbeam 1 mapdown of 200 added (A) (H)
5555 - TBS Ciel-2 129W TP 07 Spotbeam 1 mapdown of 139 added (A) (H)
5557 - ABCFM Ciel-2 129W TP 12 Spotbeam 1 mapdown of 180 added (A) (H)
5559 - TOON Ciel-2 129W TP 07 Spotbeam 1 mapdown of 176 added (A) (H)
Channel Renames:
9645(99) - BFLAY - EchoStar11 110W TP 10 ConUS beam renamed to AXETV (A)
9645(99) - BFLAY - EchoStar8 77W TP 29 ConUS beam renamed to AXETV (A)
Channels in the system: 6663
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Looks like they added Green and Tennis for Alaska and mapped down most of the HD channels as well.
To Dish Network (reading the uplink thread):
When are you going to add the mapdown channels to the Latino HD package? Range 53xx. Obviously it is not that difficult.
Thank you.
none E* never announced any p.s. E* traditionally does not launch new channels at CES look for new channels at team summit
D
12/9/2009 1:19pm - Uplink Activity Report - 12 changes
D
12/18/2009 10:59am - Uplink Activity Report - 2 changes
