What is the channel & real channel that they are using? It could be multi-path or as I discovered recently that the OTA was using VHF channel and FM was causing the problem.
channel 19 woio is 10.1 it is vhf
how do u fix that?
What? It sure does. Tell me your picture looks just as clear at 1ft from the screen as it does from 10ft. Maybe perceived PQ would be better. Granted if it was perfect at 1ft it would be perfect at nay distance, but 99% of the time that is not the case. 720p looks so,so at 10ft on my 57" vis Dish....Blu-Ray looks fantastic. So higher resolution and less compression allow me to have better PQ at same viewing distance.
I would have loved to see the post deleted between posts 135 and 136.
I needed another good laugh today.
Seating distance has nothing to do with the "Quality" of the HD image that Dish needs to achieve. Seating distance only goes to the perceived quality that the particular human sees and has nothing to do with the quality of the actual signal. If all that dish had to do was achieve good enough quality at 15 feet from a 42" television, they could get buy with a much lower bit rate.
I'm not posting for you. I am posting for the ones who ARE capable of seeing the differences and are searching for answers.
The Lord as my witness, everything I have posted is scientifically sound, accurate, and truthful.
I pray that your comments don't continue to rob more people of getting the high quality picture they deserve.
I get the same HD channels on spots which are signal 90, and on transponders where they are getting 26, they look the same, until it rains. Then the signal 26 channel stops functioning.
how do u fix that?
I wish I could screencap, the ESPN MNF game right now after a replay of a previous play they came back to live action and for about a 1/2 second the screen completely pixelated and came back into focus, just horrible stuff! I can pause it on my DVR but I don't have a way to upload it, gurrrrrrrrr
I just got a new phone and I don't have a sync cable for it yet
stupid edge network, if I was at work I would be in 3G coverage.
ok here is what I snapped, look at the 50 yard line,
this little 1/2 second blip has been happening throughout the game tonight.
Limited time offer
