lets try this again
thats how my tv looks after a 12 pack of beer! lol![]()
Again, that is comparing how bit rate affects PQ. No one disputes that. Now show me something like that with signal strength to back up your claim.
That is something that you will not see as proof. Anyone that has tuned in a sat system, or even a simple OTA antenna knows this.Nope, you missed again.
Show real world examples...screen captures of the same program with high and low signal levels that shows a PQ difference.
What you might get is another 5 or 6 paragraph technical explanation of why he must be right, and it may or may not be related to the question you asked.
The coupling between BER and SNR is a logical one. In general, the higher the SNR, the fewer the errors in the channel transmission; or simply stated, as the SNR increases, the BER decreases. Conversely, as the SNR decreases, the BER will increase, at which point the communications channel typically reduces the data rate (making each bit a little longer) in an attempt to reduce the number of errors in the transmission.
AND
Notice that as the SNR decreases, there is a graceful degradation, or roll-off, in channel performance. For example, as a 5.8 GHz signal's SNR is degraded, the channel will tend to remain operational, albeit at a reduced data rate.
Asset Tracking in Industrial Settings?A Review of Wireless Technologies Part 1: The Basics | Sensors Magazine
You bolded it, so you apparently think it's key. We have transmitters and receivers. The transmitter at Dish sends a signal to the receiver on the satellite, the satellite then transmits that signal to your receiver at home. Disagree so far?Conversely, as the SNR decreases, the BER will increase, at which point the communications channel typically reduces the data rate (making each bit a little longer) in an attempt to reduce the number of errors in the transmission.
Even the best looking BD movie will look bad at 1 foot.
That is totally not true. Blu-ray quality at any distance is noticeable and looks fantastic. Blu-ray completely kills Dish PQ (obviously, it should since the compression is much better and it is 1080p). Even Cox cable is clearly better than Dish. I did a side by side comparison while I still had both hooked up. Again, some channels are better than others. However, I should not be able to see compression artifacts when I am sitting over 10 feet away from my t.v...which is exactly what I see with Dish.
Limited time offer
