5/12/2010 11:45am - Uplink Activity Report - 69 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 5/12/2010 11:45am - 69 changes
Uplink Comparison Range: 05/12/2010 04:05A - 05/12/2010 11:45A
Channel Additions:
5160 - KTEN3 [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 36 (NA)(Ada, OK-N/A)
5160 - KTEN3 [MPEG4 HD] added to Echostar12 61.5W TP 01 Spotbeam 16 (NA)(Ada, OK-N/A)
7520 - KTEN3 [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 21 (NA)(Ada, OK-N/A)
250 - WETHR [MPEG4 SD] added to Nimiq5 72.7W TP 22 ConUS beam (NA)
381 - EPIX2 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (A)
381 - EPIX2 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (A)
856 - LAS [MPEG4 SD] added to EchoStar10 110W TP 29 Spotbeam 49 Cheyenne (NA)
4121 - HISTI [MPEG4 HD] added to Ciel-2 129W TP 26 ConUS beam (NA)
4121 - HISTI [MPEG4 HD] added to Nimiq5 72.7W TP 28 ConUS beam (NA)
4805(250) - WETHR [MPEG4 HD] added to Nimiq5 72.7W TP 32 ConUS beam (NA)
5744 - IAD13 [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
5767 - IAD10 [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
5770 - IAD1 [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
5771 - IAD2 [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
5775 - IAD6 [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
5776 - IAD7 [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
5777 - IAD8 [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
8217 - DISHW [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 30 (NA)
9521(270) - UNVSN [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (A)
9521(270) - UNVSN [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (A)
9522(272) - FTRAW [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (A)
9522(272) - FTRAW [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (A)
9526(192) - ID [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (A)
9526(192) - ID [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (A)
9527(111) - DIY [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (A)
9527(111) - DIY [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (A)
9629 - BTV [SD TV] added to EchoStar9 121W TP 13 ConUS beam (NA)
19223 - LDRAP [DATA] added to EchoStar11 110W TP 14 ConUS beam (A)
19225 - CYCLO [DATA] added to Nimiq5 72.7W TP 22 ConUS beam (A)
Channel Removals:
363 - INDIE (A) [MPEG4 HD] removed from EchoStar11 110W TP 09 ConUS beam
363 - INDIE (A) [MPEG4 HD] removed from EchoStar3 61.5W TP 31 ConUS beam
365 - RETRO (A) [MPEG4 HD] removed from EchoStar11 110W TP 09 ConUS beam
365 - RETRO (A) [MPEG4 HD] removed from EchoStar3 61.5W TP 31 ConUS beam
387 - CI (A) [MPEG4 HD] removed from EchoStar11 110W TP 09 ConUS beam
387 - CI (A) [MPEG4 HD] removed from EchoStar3 61.5W TP 31 ConUS beam
826 - LAS (NA) [MPEG4 SD] removed from EchoStar10 110W TP 29 Spotbeam 49 Cheyenne
4803 - TMP33 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 32 ConUS beam
4809 - TMP39 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 32 ConUS beam
4809 - TMP39 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 06 ConUS beam
4810 - TMP40 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 32 ConUS beam
4810 - TMP40 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 06 ConUS beam
4811 - TMP41 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 32 ConUS beam
4811 - TMP41 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 06 ConUS beam
4813 - TMP43 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 32 ConUS beam
4813 - TMP43 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 06 ConUS beam
4814 - TMP44 (NA) [MPEG4 HD] removed from Ciel-2 129W TP 32 ConUS beam
4814 - TMP44 (NA) [MPEG4 HD] removed from Nimiq5 72.7W TP 06 ConUS beam
Channel Moves:
213 - NASA [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A)
250 - WETHR [MPEG2 SD] moved from Ciel-2 129W TP 21 ConUS beam to EchoStar7 119W TP 10 ConUS beam (NA)
19225 - CYCLO [DATA] moved from Ciel-2 129W TP 21 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
Channel Package Flag Changes:
226 - DISH [MPEG2 SD] - EchoStar11 110W TP 10 ConUS beam changed to Not Available
226 - DISH [MPEG4 SD] - Nimiq5 72.7W TP 05 ConUS beam changed to Not Available
801 - KAIRA [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
Channel Renames:
4111 - TMP40 - Ciel-2 129W TP 32 ConUS beam renamed to DIY(111) (A) (H)
4111 - TMP40 - Nimiq5 72.7W TP 06 ConUS beam renamed to DIY(111) (A) (H)
4192 - TMP41 - Ciel-2 129W TP 32 ConUS beam renamed to ID(192) (A) (H)
4192 - TMP41 - Nimiq5 72.7W TP 06 ConUS beam renamed to ID(192) (A) (H)
4275 - TMP43 - Ciel-2 129W TP 32 ConUS beam renamed to UNVSN(270) (A) (H)
4275 - TMP43 - Nimiq5 72.7W TP 06 ConUS beam renamed to UNVSN(270) (A) (H)
4276 - TMP44 - Ciel-2 129W TP 32 ConUS beam renamed to FTRAW(272) (A) (H)
4276 - TMP44 - Nimiq5 72.7W TP 06 ConUS beam renamed to FTRAW(272) (A) (H)
5346 - TMP40 - Ciel-2 129W TP 32 ConUS beam renamed to DIY (A) (H)
5346 - TMP40 - Nimiq5 72.7W TP 06 ConUS beam renamed to DIY (A) (H)
5347 - TMP43 - Ciel-2 129W TP 32 ConUS beam renamed to UNVSN (A) (H)
5347 - TMP43 - Nimiq5 72.7W TP 06 ConUS beam renamed to UNVSN (A) (H)
5348 - TMP44 - Ciel-2 129W TP 32 ConUS beam renamed to FTRAW (A) (H)
5348 - TMP44 - Nimiq5 72.7W TP 06 ConUS beam renamed to FTRAW (A) (H)
5371 - TMP39 - Ciel-2 129W TP 32 ConUS beam renamed to EPIX2 (A) (H)
5371 - TMP39 - Nimiq5 72.7W TP 06 ConUS beam renamed to EPIX2 (A) (H)
Channels in the system: 7062
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.05.04
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
Live in HD!!
So, far DIY is 16x9 but SD picture quality
While, Univision and Telefutura are clearly full HD (tiny facial pores visible) .... but are 4x3 ... while ads for later programs are in 16x9 HD...
The schedule for EPIX2 looks like West Coast version of EPIX1, but the content does not match.
So Dish/Tribune messed up again, I guess, and it may really be EPIX2.
Having the wrong descriptions sure makes it hard to pick what you might want.
-Ken
Yes, we could use another weather channel because the current weather channel on 214 that we have does not show weather all of the time now. They have their own shows on. Reminds me of MTV not showing music videos all day like they used to.
The better name for 214 should be "The Commercial Channel". If you need weather, check out the services available on line. The reports on weather happenings are made to be dramatic to keep viewership levels high. Unless you are being affected by a local event, weather is booring. Check out Dish ch 100 for important local weather and forget "The Commercial Channel".
It showed EPIX2 onscreen in between movies.
-Ken
D
5/12/2010 3:07pm - Uplink Activity Report - 1 change
D
5/10/2010 12:05pm - Uplink Activity Report - 4 changes
