Depends if it's "ID" number is on the list of targeted boxes.I am getting a 722k "installed" on Monday. (The dish guy will come and hook it up to the existing cables, which I could do myself.)
Will it have the new software?
NOT in 80002, midwest, cheesvilleTopic creator must be in zip code 80002.
If you are not in zip 80002 you will not get the update yet.
There's really no timeframe. They rarely push an update to "all" receivers (of a particular model), that's for sure. It's usually spread out over 2+ weeks or more. The first, small group will get it for at least a week or so before others. This way, if there's an issue that wasn't uncovered with the very small test group, tech support isn't overwhelmed by thousands of incoming calls.How long does it usually take Dish to update every DVR of the same model with a new firmware version?
Limited time offer
