I hit the channel up button to go to ESPN2 HD and it skipped right past it. Then I figured Dish got into a pissing match with Disney again and had to take it down. I feel better now.
John Kotches said:k9sat/bob:
Command and control is probably a relatively low bandwidth requirement.Let's not confuse that with the other c, content. That's much higher bandwidth.
While redundant uplink ability would be nice, we don't know what the problem is with the sat. We also don't know how much slower it is/was because of the rain. If it's 10 or 20 percent, it may not be worth the cost for the perceived benefit.
Sadly, fiber runs aren't cheap and very few have a blank check book.
Sent from my MB855 using Tapatalk
Was wondering as well...
Did they try turning it off and turning it back on again?
".....The eccentricity (i.e. the eccentricity vector) is perturbed by the solar radiation pressure......."So that is the key. If I had solar radiation pressure I would be eccentric AND EXTREEEEMELY perturbed!![]()
They're looking for the end of the extension cord right now so they can unplug it for 30 seconds. If that doesn't work, they will call 1-800-333-DISH.
Has Dish turned on some of the channels I am not subbed to, I see Fuel channel on 398, I don't think fuel is in AT200 - is it in free preview?
What is weird is my VIP 211 is getting everything but my 722 is borked for 129 ???
You'd think they would at least turn on free Porn during this outage!
It's in AT120+ or higher. I'm on AT120+, and have had it for months.Has Dish turned on some of the channels I am not subbed to, I see Fuel channel on 398, I don't think fuel is in AT200 - is it in free preview?
K9SAT said:Yes but if there is issues sending commands due to rain at one site they should be able to send commands to another uplink site where there is no rain at that bird!
Or have some sort of fiber link to allow such commands to another location! What happens if that uplink was disabled for some reason! What I'm saying that is that commands should be abled to be issued to any bird from any uplink to keep control of the fleet!
yes its due to the outage. Dish removed them for now so you can at least watch TV (albeigh in SD)Pardon me if this has been answered, but on my HD DVR, 90% of my HD channels are gone from my guide, and only the SD channels are showing up. Is this due to this outage or is there some sort of issue on their end with giving me the correct channels, like they have made a mistaken change on my account. Everything was fine yesterday.
Limited time offer
