Also, forgot to ask but those with the Hopper 3, is the usable HD space actually 2TB because on the H2K, it's like 1.2TB available, the rest is not available.
Port 1 to the hub.... and it has to be that way!Got the installer here now and he has hooked two lines into the LNB, ran both into the house but only hooked one up to the hub. Now it won't do a check switch.
I understand that only one line is to be hooked to the lnb - can you tell me which port on the lnb the line needs to be hooked to?
We are on the Western arc - Thanks in advance for a quick reply!
I had the Darbee Darblet DVP-5000 connected to the HWS (via Denon Receiver) when I had the Sony KDL-55EX501 and loved what it did, but I removed it when I got the 4k LG55EF9500 as the Darbee is unable to pass a 4K signal.As anyone used the darbee standalone processing system with their dish? Does it really improve the image??
Thanks - the Tech came up with the same answer at the same time.Port 1 to the hub.... and it has to be that way!
You're welcome. There are several reports over the last days with the same issue.Thanks - the Tech came up with the same answer at the same time.
Really appreciate it!
OK, I finally got the full story - we still had two lines coming into the house from the dish from the 921 and VIP days. He used one line and abandoned the other but ended up using the abandoned line inside the house plus the mistake in where he attached the line to the lnb. He ended up phoning his partner that was doing and H3 install and passing the word along. The Hopper is working fine now - got all the settings restored from the old remote so all is fine.I don't understand why so may techs are hooking up to the second port on the LNB. I was always told to hook the primary receiver to the first port on the LNB.
I'm wondering why he left without getting the wireless Joey's up and running. Doesn't sound appropriate to me.He is gone now but I have a problem with getting the wireless Joey's to work. They show up on the system but can't start downloading the software - stuck with that green marching giant dots going across the screen but not downloading the software.
I will probably buy one again if the update the product.
I'm guessing the Oppo Blu Ray players process to 4k after the Darbee chip does its thing, but if it were me, I would no longer pass the Hopper signal through the Oppo.
That would explain why the box runs out of space fast. I hope it uses the full capacity for the EHD though.I haven't looked but it should be very similar.
Menu -> Settings -> Point DIsh -> Check Switch -> DetailsWhere are you getting that from. Best place is the check switch screen.
Limited time offer
