Anyone with a 4K TV hooked up to their Hopper 3? If yes can you test if 4K is working on Netflix? (I am on a different software version so I can't check)
scott i will check if it workingAnyone with a 4K TV hooked up to their Hopper 3? If yes can you test if 4K is working on Netflix? (I am on a different software version so I can't check)
Was really hoping that would be fixed!!!Yes - and you can still create a 6th folder (or more) which will be wiped out at next re-start. Still, going all the way to U307 I have to believe that a lot of "bugs" were fixed....
Blue Grass says it is there and works.Note that 4K Netflix is NOT there. Confirmed with Netflix and fully tested by me in a complete, confirmed system that plays 4K almost every day, just not from Netflix on the H3. Netflix 4K does work on the FireTV.
Sent from my iPad Pro using Tapatalk
on the screen it shows movies and titles it shows that there is ultra4khd i cannot do ultra4khd becase of the bandwidth so folks if you have fast internet speed i would try it out all i am doing is replying to what scott posted here.Blue Grass says it is there and works.
So which is it lol.
Samsung Galaxy S6 Active
Alan, that list will show the availability of 4K videos, but on the H3 it will NOT play them in 4K. It has done that since day one. Nothing new about it at all.on the screen it shows that shows movies and titles it shos there is ultra4khd i cannot do ultra4khd becase of the bandwidth so folks if you have fast internet speed
That's what I figured, you don't need an H3 to know that's what happens when you don't have proper bandwidth.He doesn't have the bandwidth necessary to actually know. He even says so. I think he just did a search for "4K" and got the grid of 4K videos. Since Netflix tests bandwidth if he actually selects the show it will show it only in HD, not 4K.
Yep, been there, done that!!Don't forget that with 4k Netflix you need to be on the $11.99 Netflix package.
Strange I got the update. Netflix is indeed showing 4k on my Samsung TV. Plus I do get dolby digital with Netflix nowThe 4K programs were showing up on Day 1 with the H3, just won't play them in 4K yet as you noted.
That is strange! I'm still getting HD and stereo.Strange I got the update. Netflix is indeed showing 4k on my Samsung TV. Plus I do get dolby digital with Netflix now
For me, it takes 17 seconds from power up for the home page to go away so I still need the CANCEL command in the power up sequence. I also need a delay of 1.5 seconds between power up and cancel so this is delaying power up.yeah - after updating and by the time my TV lit up I was on "live" TV - that should make a lot of people happy!![]()
Limited time offer
