The Few, The Proud, The ones with big"SatelliteGuys Folding - Quality, not Quantity"
Watch out if they mention this bridge they can sell you……and am assured that the bonus points are not lost and will be applied at some later date.
It seems to be project 14180 that is the worse. My GTX 750 Ti takes over 15 minutesto process one Frame. My RTX 2060 is working one 14180 PRCG WU at an estimated 150K PPD when it was pushing almost a million PPD on less annoying Project's Work Units.
What size power supply(ies) are/is used on something like that?This is what I worked on this afternoon. It has to be ready to start deep learning by the end of the day tomorrow, so no time for folding.
I'd be curious to know if the one GPU with an open fan has significantly lower Temps than the other seven.
| NVIDIA-SMI 418.67 Driver Version: 418.67 CUDA Version: 10.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 Quadro RTX 6000 Off | 00000000:1A:00.0 Off | Off |
| 33% 37C P0 62W / 260W | 0MiB / 24190MiB | 0% Default |
| 1 Quadro RTX 6000 Off | 00000000:1B:00.0 Off | Off |
| 34% 35C P0 63W / 260W | 0MiB / 24190MiB | 0% Default |
| 2 Quadro RTX 6000 Off | 00000000:3D:00.0 Off | Off |
| 34% 34C P0 56W / 260W | 0MiB / 24190MiB | 0% Default |
| 3 Quadro RTX 6000 Off | 00000000:3E:00.0 Off | Off |
| 34% 37C P0 61W / 260W | 0MiB / 24190MiB | 0% Default |
| 4 Quadro RTX 6000 Off | 00000000:88:00.0 Off | Off |
| 34% 34C P0 53W / 260W | 0MiB / 24190MiB | 0% Default |
| 5 Quadro RTX 6000 Off | 00000000:89:00.0 Off | Off |
| 32% 34C P0 64W / 260W | 0MiB / 24190MiB | 0% Default |
| 6 Quadro RTX 6000 Off | 00000000:B1:00.0 Off | Off |
| 34% 36C P0 58W / 260W | 0MiB / 24190MiB | 0% Default |
| 7 Quadro RTX 6000 Off | 00000000:B2:00.0 Off | Off |
| 35% 34C P0 57W / 260W | 0MiB / 24190MiB | 3% Default |
Limited time offer
