I received H373 update overnight. Haven't had a chance to check and see what has changed. Good luck to everyone.
I received H373 yesterday. One thing I noticed is a "Signal Protector " popup during weather related signal loss. The popup offers to switch to streaming instead. There is a check box to make it automatic. Works quite well so far. I haven't found a way to uncheck the box that makes it automatic.I received H373 update overnight. Haven't had a chance to check and see what has changed. Good luck to everyone.
I'm only aware of WE channel 128. I'm sure there are others.Which channels can "fail over" to streaming?
Yes as far as I know.That would occur only when you are watching live tv?
No it all happens on the same channel on the Hopper. The message says it streams over the internet.Does it send you to Sling streaming of the same show?
I found the setting on the Diagnostic page. Press Home 3x then Network then Internet settings the Advanced tab. The feature can be turned on and off here.Please keep us informed. Sounds like we MAY have a nice feature here.
Do you have H373 software?
I'm on 373 and not seeing any kind of streaming related settings.Do you have H373 software?
See my post #11I'm on 373 and not seeing any kind of streaming related settings.
I downloaded H373 on my H3 & H3 Plus. I see the new Signal Protector setting in my H3, but not my H3 Plus. Do you know why not for my H3 Plus?I found the setting on the Diagnostic page. Press Home 3x then Network then Internet settings the Advanced tab. The feature can be turned on and off here.
NopeI downloaded H373 on my H3 & H3 Plus. I see the new Signal Protector setting in my H3, but not my H3 Plus. Do you know why not for my H3 Plus?
Limited time offer
