DIRECTV Transponder Map ~ Data 3/12/2025 | Page 70 | SatelliteGuys.US
DirecTV Satellite Transponder Updates for Jan 29 2025
Comparison of Transponder Data for Jan 29 2025 vs Jan 22 2025:
No changes in system tables for any transponder tuning parameters.
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
4​
HD​
277​
1​
1450​
SD mpeg4
138​
196​
SD mpeg2
444​
-4​
RB​
Audio​
89​
Push​
30​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
36​
2​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
Weekly Analysis soon
Enjoy
DataDigesters
Reactions: lordodogg
In addition to FIREAID on 101,
9753 *PPGEM - Protection Plan Gemini Upgrade and 9757 *SWITCH - Save $12/month with no locals are testing
Hallmark Movies Now -> Hallmark+ on channel 1922
The MLS Season Pass channels are now live
The HD slate is repurposing "Dispute Slide 2 Test 9110" on 103ca TPN 8, PID 1150
The SD slate is repurposing "Slide Test SD 9402" on 101 TPN 25, PID 003C
Also, 2135 SporTV will be ceasing their international distribution on 2/28
DirecTV Satellite Transponder Updates for Feb 05 2025
Comparison of Transponder Data for Feb 05 2025 vs Jan 29 2025:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
4​
HD​
276​
-1​
1450​
SD mpeg4
139​
1​
196​
SD mpeg2
449​
5​
RB​
Audio​
89​
Push​
30​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
31​
-5​
Enjoy
DataDigesters
In addition to the ShopHQ withdrawal and FireAid being done
A College Sports Mix is now on channels 205-2 and 600-2
Tucson's KGUN has been added to portions of the Phoenix DMA
9753 PPGEM (Gemini upgrade), 9755 GIFT (NHLCI on us), 9757 SWITCH (no locals) are now live
LOOLOO and C-SPAN2 are now live for Puerto Rico
Passing along Gracenote's update of WDTVDT's RF number
DirecTV Satellite Transponder Updates for Feb 12 2025
Comparison of Transponder Data for Feb 12 2025 vs Feb 05 2025:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
4​
HD​
276​
1450​
SD mpeg4
139​
196​
SD mpeg2
448​
-1​
RB​
Audio​
89​
Push​
30​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
1​
1​
SD mpeg2
RB​
Engr Work​
32​
1​
Rapid City SD SD_LILs removed ??
Enjoy
DataDigesters
NBCU's diginet American Crimes is testing on channel 85, which means SAVE will be moving
- It is using the TPN slot that used to belong to Viendo Movies
9759 *PEACOCK offer is testing
Cleanup of the leftover Denver Ku offline records from the Rapid City DMA
The NFL schedule app has been removed from channel 702
Passing along Gracenote's update for WSFJDT2 Columbus
Channels 901-907 have been repurposed for bonus Indian Wells coverage from the Tennis Channel between 3/5-3-12
The batch of Infomercial channels on 85 have moved to subchannels on 98
I think on Stream, it'll be another "duplicate" channel 668 because of their incompatibility with sub-channel channel numbers.
On Satellite, however, it'll more than likely be on 668-3.
I kinda figured that's where it would be. I was trying to explain to my stepdad (directv satellite sub) where the Twins channel 'might be'. Stream its interesting how they can't do a -1 or -2 so subs will have 3 channel 668 and a 669 for subs.
Dishpointer Pro "not licensed"
