110/119 Listings Post 129 Transition (Updated 5/26/2025) | Page 7 | SatelliteGuys.US
Hey zippy, since you're in the Chicago DMA, check to see if you're now getting WTVK-59 HD in your locals lineup...DISH's website is now indicating this, though they have it listed as from Peoria.
I do not receive it via Dish. However, WTVK is available OTA - it is ShopHQ. I have received 59 OTA for a couple of years now. I just checked Dish's website and sure enough it is listed as a Chicago local - but it does not show up as a satellite local. Thanks for pointing that out on the Dish website - I didn't see that update.
Reactions: charlesrshell
I did my monthly scan, and the only thing I noticed different is that the cycling Boost Mobile ad, which was previous on channel 9547, was removed. That frees up one more HD slot on 110, TP 14. No other movements between transponders. The Cozi slate is on 110, TP 24, which is the same location Cozi was before it went into dispute.
Is there any conus local channels still available?
I don't know for sure. Before 129 was shut down, there were a couple of markets that were on the continental transponders. The one thing I would say is that from all the scans that I have done, I don't have any channels on 110 TP 6, and that conus transponder had locals before the changes.
I did a scan today after the uplink occurred, and everything is still status quo for the channels I can see on my VIP211k. The only thing that I noticed a week or two ago is that channel 9547 is back - a new Boost Mobile ad.
Today Dish added NRBTV on 274 on 110, TP 10. I will have some time over Thanksgiving Break and will be updating the full listings at that point.
Dish just had an uplink to add the Yule Log channels. On channels 298 (Modern Yule Log) and 304 (Classic Yule Log). They are on 110, TP 24. Same transponder location as last year. However, they have the Modern Yule log on 298 this year whereas last year it was on 303, right next to the Classic Yule Log.
80 is the previous Christmas Dish Scapes, also on 110, TP 24.
Since I had some time over the Thanksgiving holidays, I was able to go back and update my original listings of what transponders each channel is on for Western Arc. There have been no changes in terms of what is where - very stable since 129 went away. A couple of the holiday channels were added back, but on the same transponders as last year. Adding NRBTV 2 weeks ago is taking the transponder space from NASA when it shut down earlier this year.
Today is an interesting day looking at the space that Dish has on it's satellites. We don't see this often, but with all the NBA and NHL games going this evening, Dish might run out of space. On NBA League Pass tonight, the Pistons/Lakers game has the dreaded Joined In Progress and the feed is coming from 110, TP 15. I personally think that the Pistons/Lakers game will be seen in it's entirety because Dish has allocated 4 hours per NBA game, and all the east coast games that start 3.5 hours earlier should be completed. I am not aware of any NBA game taking more than 3.5 hours this year. But interesting to see that. The only other time I recall seeing this since 129 went away was the start of baseball season when there was MLB and NBA going on at the same time.
Yesterday afternoon Dish added OAN to the lineup - HD on channel 212. It is on 110, TP 21 on Western Arc. I don't recall seeing any press release on it.
Cordcuttersnews.com posted about Sling adding it
I updated the list this morning. No movement on the current channels between transponders the past couple of weeks. Only change was that the Cozi info slate on 253 has been completely removed.
Today's uplink did remove FMC from 387 for those of us with older receivers. I assume it is now available in HD as a streaming channel on 387? I can't see for sure since I have a VIP211k
Dish Change Question
First Look - New Dish 721 Software with OpenTV!
