My version B with L401 did the same thing. Mine was just wounded, I got them back by doing a power cord reboot. Sounds like it killed yours.
What is version B?
I lost all my OTA locals after watching NCAA on CBS for quite awhile. Luckily, a reboot brought them all back. The receiver had been on about 4 1/2 hours when the OTA's were lost.
Everything works except I lost all my OTA locals. It's as if the OTA tuner has been turned off inside the receiver. Tech help was no help, it's being returned. If anyone else has had this problem and fixed it help. I love everything else about the update. I have checked switch numerous times and deleted locals, rescanned rebooted, you name it. I don't know of anything else to do.
No signal on any OTA channel. All of them were still in the guide.
I reported this too as well as the fact if you lock out the mpeg4 hd locals in the 6000 range and only use the channel map down to the lower numbers, you get no search results for either channel in the hd range. So you can not use channel map down mirrored channels without leaving the larger number versions of the same channels out of the lock out option. I see a problem with this. How many people want several channels in different ranges all cluttering up thier guides? And how will Dish eventully replace all sd channels with thier hd versions if they are mirrored to there lower sd channel numbers and the search features don't work? This needs to be addressed as it limits all search features with the mapdown channels. I consider this a major bug .
I just had the same thing happen with mine (L4.01). It won't even attempt to scan for channels. I have tried everything but a power cord reboot.
I saw this same thing this morning. the fix was a power cord reset.
(Dutifully reported to E*).
LER
What do you mean by "power cord reset"? I held the power button in for 5 seconds to force a reboot and got the OTA's back.
Mine would only come back after the power cord reboot as well.
I wish they would display the HD label next to local OTA channels as well. This would be most helpful in the DVR recordings list, so we could determine where all of the hard drive space has gone.
Limited time offer
