I hope, by now, this really is. I made drawing, bought material, friend of mine did TIG welding, I just put everything together and made more or less proper adjustments. Of course, it did cost some $, but, so what?kind "only one in the universe" kind of thing !!
Hi! And you promised in that thread to show us some picturesI thought there was a thread kicking around here on the same dish.
From the very beginning my goal was to get performance of offset antenna (in my case it was 1,8m Prodelin) better by making it work as a Gregory-type (with ellipsoidal sub-reflector). I've read that Gregory-type systems perform better than offset antennas as they use more effectively surface of main dish and also exclude X-pol. So, I got sub-reflector from factory made Gregory and made proper mechanical fittings. Of course, to make conclusions on which setup is working better we need to do some comparison-tests. For tests I took several LNBs:
- Inverto Black Ultra (white label, some people say that there is difference between performance of IBU with white and red label);
- IBU red label;
- IBU red label adopted by one company for antennas with 70* illumination angle;
- IBU red label 90* illumination;
- Gold LNB adopted to work with original Prodelin feedhorn;
- Invacom single attached to Gregory feedhorn;
- Octagon twin attached to Gregory feedhorn;
- IBU red attached to Gregory feedhorn;
I measured signal levels on all available in my area frequencies from Eutelsat @ 28,2*E (could be any) and put data in spreadsheet. I've got 58 transponders. Then I calculated average signal level.
So, after all this I can say that Gregory systems performing better than usual offset dish. And, secondly, by attaching sub-reflector to offset antenna is possible to get better performance of system. It is like you change 1,8m antenna to 2 meter.
View attachment 100199 View attachment 100200 View attachment 100201
I will answer here in case this is interesting to somebody else.I just sent you a PM about this project
I have a Prodelin 1,8 meter, 1194 series antenna. Unfortunately, I do not have feed rod and feed support tube. Well, the problem is that I cannot find focal point. So I am wondering whether you could help me in order to find the focal point in inch.I just bought an used Prodelin 1.8 Mts. 0179-189 dish, but when I search in the Prodelin website for its specifications and/or Diagrams, they are clasified by series numbers: 1183, 1184 for example.
Please does anyone could tell me the series number for this 1.8 Mts Prodelin 0179-189?
Or could post its specifications and/or diagrams?
Limited time offer
