1.8 prime f. | SatelliteGuys.US
1.8 prime f.
lme
119
9
Ontario
Waiting for the actuator & positioner to arrive and start the set up in spring.
What type of cable do i need from the positioner to the actuator & where it can be purchased ?
Underground sprinkler wire seems to work fine for most people. Check your local hardware, Menard's , Lowes, Home Depot , etc for the best price and selection.
I used a roll of 4 conductor telephone wire...solid wire not the stranded stuff. I put it underground in 1/2" pvc last year and it's working great. It worked ok and was a lot cheaper than the sprinkler wire I saw at H. Depot....blind
I think i just put in the garbage few weeks ago a good length of this type of wire. Is it like a 2 wires ribbon cable ?
I think mine came from Ratio Shack on a small spool. Round cable 4 conductor..item # 278-872 for $6.99 a 50 foot roll. It said 24 gauge. It has worked thru one summer and a bitter cold snowy winter....Blind
HI everyone,
I use thermostat wiring. mine has 6 conductors all color coded with extra tuff jacketing. bought mine at menards, but you can buy it at most hardware stores.Little more expensive ,but very durable.
Cant get music choice.
DigiCipher II Single Channel Encoder
