1.8--Waiting for channel load | SatelliteGuys.US
rsmith3400
19
PROBLEM DESCRIPTION
OS: XP Professional 2002 SP2
TT Version: 1.8
TT Mode: XM Online
I'm trying to connect, but all i get is "waiting for channel load. Anyone have any suggestions. I uninstalled and re-installed already. Thanks
We will need info from the TT on this one. If you are only receiving it then it could be just local to you... we need to see who else might be having this issue.
*remember, in the past, things like this happened and forced updates to the software*
Wonder what you CAN do.
Have you used the "cleaner" util that was provided to help remove all peices and parts of TT from your computer? Wonder if that helps..
Version 1.8
Sirius Drivers
