1 coax or 2 coax from 622? | SatelliteGuys.US
KostaVan
35
Quick question.
I am going to be using a dish 1000 with the 622. Am I going to have to run 1 coax or 2 because one is already run for the old Voom I use to have. Will I need to have another line run to the 622 or will it be fine with just one coax? Thanks.
-Kosta
One should be fine. The DPP Twin on the Dish 1000 can feed a separator at the receiver for both inputs with one line. If you have more than two receivers, Dish should install a DPP44 switch, with the same properties.
FireFox Browser with dishnetwork.com
What to do with old 6000
