10 Foot dish. Finding the right place to plant it. | SatelliteGuys.US
iBoston
2,661
2,230
North Central
How long of a run can you have? Do you need a signal booster at some point? Cband prime focus dishes do not have any offset. correct? So, they point directly at the satellite. I ask, because i want to use an app on my cell to view all the satellites in the sky so i know i can see them all from a specific location.
The shorter the run, the better. 125 to 200 feet is fine with good quality quad shielded RG-6 coax with solid copper core. A run over 250 feet might benefit from a quality amplifier, but it will degrade the satellite signal. The longer the run, the more switch and motor control problems. Do not go cheap on the coax cable if you are installing a long run. Might even consider RG-11 solid copper core for runs over 250'.
The prime focus design has no offset angle, but that makes no difference when performing a site check. Both a prime focus and an offset design look at the same point in the sky and the reflector must be fully illuminated by the satellite signal. The app does not care what the reflector type is. It only shows you wher the satellite is positioned in the sky.
Reactions: Dee_Ann
Signal Strength Bar Goes On and Off
SOmething wrong with SES-6 ( 40.5W)?
