is ktla and bounce tv still there cant seem to scan any horizontal channels.is the lnb bad its a bsc42 lnb
ok thanksYep, still there. Check your coax connections for corrosion. Can introduce high resistance lowering the LNBF voltage causing horizontal to go by by.
Titanium C1-PLLok thanks for the help can you recomend a lnb
Limited time offer
