1080p with ce | SatelliteGuys.US
1080p with ce
mooney1324
7
Chicago
I just noticed that while on the latest CE build (0596) the option for 1080p says (TV doesn't support). I know my TV supports 1080p, and it was able to be selected before. Is this a known issue? I tried searching for it on the boards, but couldn't find it. Thanks for the help!
The tv is 1080p supported, and I have HDMI in use with it. I wonder if going through my sound bar that disables the 1080p. Ill have to try to hook it up straight to the tv when I get home from work. I have all new High Speed HDMI cables so I know its not those. My XBOX 360 and PS3 both still show 1080p when I play them. Those are hooked up through the sound bar as well. Ill play with it later and see what I can get.
HR34 getting new HD-GUI
H2x / HR2x CE Release 12/30 v.0596/v.4596
