1080p | SatelliteGuys.US
1080p
carlosg
83
does the ps3 downscale games that are 1080p to 480 if your tv is 1080i
If the game has 720p output only and your set cannot receive a 720p signal then the PS3 will downscale to 480p. 1080p games will display at 1080i or 720p depending on what you HDTV's native HD resolution is.
Right now the only problem is with 1080i sets that can not recieve a 720p signal for conversion. Because the set can not recieve and convert the signal a 720p signal would show up on these sets as snow (ie. no pictuer or sound). In this case the PS3 would downconvert the 720p signal to 480p for viewing.
While all new sets recieve 720p either as a native signal or to upconvert within the set to 1080i the first 1080i HDTVs (primarily rear projection sets and not DLP) had native resolutions of 480p and 1080i. They ignored the 720p signal until Fox and ABC started using 720p. Now all new HD sets support 720p one way or the other.
PS3 60Gb as a wireless bridge?
Harmony 1000 & Xb0x 360
