11/10/2016 12:19 - Uplink Report - 39 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 11/10/2016 12:19 - 39 Changes
Uplink Comparison Range: 11/10/2016 12:13 - 11/10/2016 12:19 (PST)
Channel Additions:
6100 - XCD00 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD00)(NA)(H)
6101 - XCD01 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD01)(NA)(H)
6102 - XCD02 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD02)(NA)(H)
6103 - XCD03 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD03)(NA)(H)
6104 - XCD04 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD04)(NA)(H)
6105 - XCD05 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD05)(NA)(H)
6106 - XCD06 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD06)(NA)(H)
6107 - XCD07 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD07)(NA)(H)
6108 - XCD08 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD08)(NA)(H)
6109 - XCD09 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD09)(NA)(H)
6110 - XCD10 [MPEG4 HD] added to EchoStar14 119W TP 15 ConUS (XCD10)(NA)(H)
6111 - XCD11 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD11)(NA)(H)
6112 - XCD12 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD12)(NA)(H)
6113 - XCD13 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD13)(NA)(H)
6114 - XCD14 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD14)(NA)(H)
6115 - XCD15 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD15)(NA)(H)
6116 - XCD16 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD16)(NA)(H)
6117 - XCD17 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD17)(NA)(H)
6118 - XCD18 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD18)(NA)(H)
6119 - XCD19 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD19)(NA)(H)
6120 - XCD20 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD20)(NA)(H)
6121 - XCD21 [MPEG4 SD] added to EchoStar14 119W TP 15 ConUS (XCD21)(NA)(H)
6122 - XCD22 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD22)(NA)(H)
6123 - XCD23 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD23)(NA)(H)
6124 - XCD24 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD24)(NA)(H)
6125 - XCD25 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD25)(NA)(H)
6126 - XCD26 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD26)(NA)(H)
6127 - XCD27 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD27)(NA)(H)
6128 - XCD28 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD28)(NA)(H)
6129 - XCD29 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD29)(NA)(H)
6130 - XCD30 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD30)(NA)(H)
6131 - XCD31 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD31)(NA)(H)
6132 - XCD32 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS (XCD32)(NA)(H)
Channel Removals:
817 - ORDER [MPEG2 SD] (A) (FP) removed from EchoStar14 119W TP 10 ConUS (PPV Event Pre-Order)
817 - ORDER [MPEG4 SD] (A) (FP) removed from Nimiq5 72.7W TP 29 ConUS (PPV Event Pre-Order)
818 - ORDER [MPEG4 HD] (A) (FP) removed from Nimiq5 72.7W TP 29 ConUS (PPV Event Pre-Order)
818 - ORDER [MPEG4 HD] (A) (FP) removed from EchoStar11 110W TP 10 ConUS (PPV Event Pre-Order)
MAP Changed:
4204(252) - TRU [MPEG4 HD] Nimiq5 72.7W TP 26 ConUS map changed to (242) (truTV)(A)(H)
4204(252) - TRU [MPEG4 HD] Ciel-2 129W TP 29 ConUS map changed to (242) (truTV)(A)(H)
Transponder Changes:
EchoStar14 119W TP 15 ConUS (21.500 8PSK 2/3) added.
EchoStar11 110W TP 10 ConUS (21.500 8PSK 2/3) removed.
Nimiq5 72.7W TP 29 ConUS (21.500 8PSK 2/3) removed.
Channels in the system: 9596
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated
11/10/2016 06:08 - Uplink Report - 93 Changes
12/07/2016 06:31 - Uplink Report - 60 Changes
