110w sat down? | SatelliteGuys.US
110w sat down?
Musher
101
trying to watch ESPN HD and 110w went off about 1:30pm Central time and did the signal quaility and it could not lock on to it and now at 1:43pm still the same.
Musher
Edit: Now its back up at 1:45pm I even lost HDNet and the other HD channels at 110w, weird?
[ame]http://en.wikipedia.org/wiki/Solar_transit[/ame]
It is spring... The Sun drowns out the satellites briefly in the afternoon.
Yes I know about the solar thing but the channels on 61.5,119,129 came in at the same time when I could not get any channels from 110 or maybe my receiver had hardware fart (just like a brain fart):) who knows.
Musher
You will get signal loss at different times of the day for each satellite as the sun tracks accross the sky. The farther west you go in the arc, the later in the day for the signal loss.
It when the sun appears to be directly behind the satellite you are looking at from your location that it gets drowned out. Since the satellites are scattered across the sky the sun drowns them out one by one as it moves across the arc.
Yep, if you were watching the other satellites when it happens, you would lose them too.
There should be a site out there that gives you the times for your zip code.
I know the satellite receivers at work give us a warning and show the time to expect sun fade.
It happen again today at the same time so it is Solar Outage cause it was the same time for 1:30pm to 1:45pm but the main thing is I missed the first 5 minutes of the Marquette Basketball Game. They did Nova' to move on in the Big East tournament at MSG in NYC.
Musher
Everyone who receives a satellite signal from anything has this problem... It's just different times for different places and it depends on what satellite you are aimed at.
While you may lose, say 61.5... Your 110/119 combo would still be fine... When your 110 is out, your 61.5 and probably your 119 would work, etc...
Early termination question
Franklin County, PA
