1224 Supermount Motor | SatelliteGuys.US
Not me, but there is one simular (I think?), that is hard to find, because they no longer make them. It's an AJAK "Patriot" H to H motor. There were 2-3 left, last time I looked. These were made for "Polar Mounts" (I think on Patriot 6'-8' dishes or smaller), so not knowing what you need, it may not work without modifications.
http://www.global-cm.net/
Go in the "BARGAINS" section to get to it. If you call about it, they can tell you if it will work for what you want. Check it out and see......?
Al
g10r signal- lower than normal?
pansat 2700E
