125W Ku | SatelliteGuys.US
125W Ku
StarScan
438
59
North Liberty, Indiana
I haven't had much luck aiming my .75M Channel Master dish at 125W. What is a good sampling rate? I"m using a single polarity Channel Master LNB which is set to horizontal and a CoolSat 6000 FTA.
You may want to try 11982 V30000 3/4, its scrambled but a very strong signal to help you locate 125W.
Then you can blind scan to find the other TPs. Most of the active TPs are vertical. Also all the TPs are DVB-S2. No DVB-S.
CS 6000 won't do S2 and won't see anything on 125w. It also doesn't do AC3 and several other useful things. Pretty much a paperweight now.
There use to be one DVB TP on 125W
12175 H 4444
but I assume that went S2 also (again the last time I played with FTA was Nov 2012) ;)
Sony DSS SAT -A3
AzboxMinime again.
