129 tp27 | SatelliteGuys.US
129 tp27
cebbigh
1,601
Frostbite Falls
Ocasionally while viewing Universal I'll see the picture morph into an image from Kansas City Fox4. This has happened during both Stargate Atlantas and Battlestar Galactaca. It has also happened while viewing a movie on Max (high def). I'm using a 24 inch dish to boost signal in the Seattle area. The last time it happened I readjusted the dish to boost the signal (got tp 27 to increase peak signal from 68 up to 82). I have seen it do it only once briefly since the adjustment so it appears to have improved it. But it seems weird that it would happen to begin with. I think KC Fox4 is on 129 tp1 and it isn't like I see that TP any stronger than 27.
Anyone else has seen this or any suggestions?
You're right, WDAF, FOX4 KC is on 129, TP1. This might have something to do with signal bleed at the uplink, but what do I know?
Brad
622 TV2 Output
622 Sound Issue
