Bob Thompson New Member Original poster Jul 25, 2021 1 0 Oregon Jul 25, 2021 #1 How to get rid of the 1592 code about the snap USB connection on hopper 3. Yes my Joey in the other room is hard wired?
Jim5506 SatelliteGuys Master Pub Member / Supporter Lifetime Supporter Oct 19, 2004 8,381 3,957 Slaton, Texas Jul 25, 2021 #2 Snap is not made for use on the Hopper 3, only for the Hopper 2000 to speed up the video processing of menus, IIRC. Last edited: Jul 25, 2021 Reactions: Howard Simmons and charlesrshell
HipKat SatelliteGuys Master Pub Member / Supporter Aug 25, 2017 20,622 41,679 Pekin, IL Jul 25, 2021 #3 Jim5506 said: Snap is not made for use on the Hopper 3, only for the Hopper 2000 to speed up the video processing of menus, IIRC. Click to expand... And the Hopper w/Sling Reactions: navychop, Howard Simmons, Bobby and 2 others
M Murpeg New Member Jan 9, 2023 1 2 Pagosa springs co Jan 9, 2023 #4 Just had tech by to fix remove the unit plugged into the top USB port on the back u no longer need it This also fixed 9999 restarting Reactions: TheKrell and charlesrshell
HipKat SatelliteGuys Master Pub Member / Supporter Aug 25, 2017 20,622 41,679 Pekin, IL Jan 9, 2023 #5 Murpeg said: Just had tech by to fix remove the unit plugged into the top USB port on the back u no longer need it This also fixed 9999 restarting Click to expand... The only way the Snap is not needed is on a Hopper 3, Hopper Duo or a Hopper w/Sling with a Hopper Plus Reactions: navychop and charlesrshell
