18inch CP | SatelliteGuys.US
18inch CP
havenx
211
Okay so I have this 18 inch dish with a CP LNB on it. Will it pick up the radio on EchoStar 7, and what is with the L and R? I have seen H and V and understand that but what is L and R?
Yes that dish will work for FTA DBS radio and the few channels (Gol TV / NASA..)
The L.O. should be set to 11250
L and R mean RIGHT and LEFT polarization.
Linear signals come down from the satellite in a straight line, horizontally or vertically.
Circular signals come down from the satellite in a spiral, left hand or right hand (polarized)
Have a look half way down this link for a diagram......
http://www.geo-orbit.org/sizepgs/tuningp2.html#anchor713284
Added a link to the above to better explain and to help visualize.....
havenx said:
Is L and R a DBS thing for CP?
yep..Circular is mostly used in DBS. Doesnt matter how the LNB is, it works the same...cant do that with a KU band :)
as for polarity
R=Vertical
L=Horizontal
PBS on AMC3
Pansat 3500 Setting
