2/11/2017 07:38 - Uplink Report - 102 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 2/11/2017 07:38 - 102 Changes
Uplink Comparison Range: 2/06/2017 11:44 - 2/11/2017 07:38 (PST)
Channel Additions:
26015 - VCAJP [b7] added to Anik F3 118.7W TP 28 ConUS (VCAJP)(A)(H)
26016 - VCAJP [b7] added to EchoStar14 119W TP 05 Spotbeam A27 (VCAJP)(A)(H)
Channel Number Changed:
891 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS channel number changed to 541 (MLB)(A)(H)
891 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS channel number changed to 541 (MLB)(A)(H)
890 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 542 (MLB)(A)(H)
892 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS channel number changed to 542 (MLB)(A)(H)
893 - MLB [MPEG2 SD] EchoStar14 119W TP 10 ConUS channel number changed to 543 (MLB)(A)(H)
893 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS channel number changed to 543 (MLB)(A)(H)
892 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 544 (MLB)(A)(H)
890 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS channel number changed to 544 (MLB)(A)(H)
895 - MLB [MPEG2 SD] EchoStar14 119W TP 16 ConUS channel number changed to 545 (MLB)(A)(H)
894 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS channel number changed to 545 (MLB)(A)(H)
894 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 546 (MLB)(A)(H)
895 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS channel number changed to 546 (MLB)(A)(H)
897 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS channel number changed to 547 (MLB)(A)(H)
897 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS channel number changed to 547 (MLB)(A)(H)
898 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS channel number changed to 548 (MLB)(A)(H)
898 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS channel number changed to 548 (MLB)(A)(H)
899 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS channel number changed to 549 (MLB)(A)(H)
899 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS channel number changed to 549 (MLB)(A)(H)
900 - MLB [MPEG2 SD] EchoStar14 119W TP 10 ConUS channel number changed to 550 (MLB)(A)(H)
900 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS channel number changed to 550 (MLB)(A)(H)
901 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS channel number changed to 551 (MLB)(A)(H)
901 - MLB [MPEG2 SD] EchoStar11 110W TP 09 ConUS channel number changed to 551 (MLB)(A)(H)
902 - MLB [MPEG2 SD] EchoStar14 119W TP 16 ConUS channel number changed to 552 (MLB)(A)(H)
902 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS channel number changed to 552 (MLB)(A)(H)
896 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 553 (MLB)(A)(H)
896 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS channel number changed to 553 (MLB)(A)(H)
904 - MLB [MPEG2 SD] EchoStar14 119W TP 16 ConUS channel number changed to 554 (MLB)(A)(H)
904 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS channel number changed to 554 (MLB)(A)(H)
903 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 555 (MLB)(A)(H)
905 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS channel number changed to 555 (MLB)(A)(H)
906 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS channel number changed to 556 (MLB)(A)(H)
906 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS channel number changed to 556 (MLB)(A)(H)
907 - MLB [MPEG4 SD] Echostar16 61.5W TP 11 Conus channel number changed to 557 (MLB)(A)(H)
907 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS channel number changed to 557 (MLB)(A)(H)
908 - MLB [MPEG2 SD] EchoStar14 119W TP 16 ConUS channel number changed to 558 (MLB)(A)(H)
908 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS channel number changed to 558 (MLB)(A)(H)
905 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 559 (MLB)(A)(H)
909 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS channel number changed to 559 (MLB)(A)(H)
909 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 560 (MLB)(A)(H)
910 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS channel number changed to 560 (MLB)(A)(H)
910 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 561 (MLB)(A)(H)
911 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS channel number changed to 561 (MLB)(A)(H)
912 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS channel number changed to 562 (MLB)(A)(H)
912 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS channel number changed to 562 (MLB)(A)(H)
911 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 563 (MLB)(A)(H)
913 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS channel number changed to 563 (MLB)(A)(H)
913 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 564 (MLB)(A)(H)
914 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS channel number changed to 564 (MLB)(A)(H)
914 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS channel number changed to 565 (MLB)(A)(H)
903 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS channel number changed to 565 (MLB)(A)(H)
MAP Changed:
5101(900) - MLB [MPEG4 HD] Nimiq5 72.7W TP 20 ConUS map changed to (550) (MLB)(A)(H)
5101(900) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS map changed to (550) (MLB)(A)(H)
5102(901) - MLB [MPEG4 HD] Nimiq5 72.7W TP 26 ConUS map changed to (551) (MLB)(A)(H)
5102(901) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS map changed to (551) (MLB)(A)(H)
5103(902) - MLB [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS map changed to (552) (MLB)(A)(H)
5103(902) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS map changed to (552) (MLB)(A)(H)
5104(903) - MLB [MPEG4 HD] Nimiq5 72.7W TP 20 ConUS map changed to (553) (MLB)(A)(H)
5104(903) - MLB [MPEG4 HD] Ciel-2 129W TP 28 ConUS map changed to (553) (MLB)(A)(H)
5105(904) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map changed to (554) (MLB)(A)(H)
5105(904) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS map changed to (554) (MLB)(A)(H)
5106(905) - MLB [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map changed to (555) (MLB)(A)(H)
5106(905) - MLB [MPEG4 HD] Ciel-2 129W TP 19 ConUS map changed to (555) (MLB)(A)(H)
5107(906) - MLB [MPEG4 HD] Echostar16 61.5W TP 05 Conus map changed to (556) (MLB)(A)(H)
5107(906) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS map changed to (556) (MLB)(A)(H)
5108(907) - MLB [MPEG4 HD] Echostar16 61.5W TP 05 Conus map changed to (557) (MLB)(A)(H)
5108(907) - MLB [MPEG4 HD] EchoStar11 110W TP 15 ConUS map changed to (557) (MLB)(A)(H)
5109(908) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map changed to (558) (MLB)(A)(H)
5109(908) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS map changed to (558) (MLB)(A)(H)
5110(909) - MLB [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS map changed to (559) (MLB)(A)(H)
5110(909) - MLB [MPEG4 HD] Ciel-2 129W TP 27 ConUS map changed to (559) (MLB)(A)(H)
5111(910) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map changed to (560) (MLB)(A)(H)
5111(910) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS map changed to (560) (MLB)(A)(H)
5112(911) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map changed to (561) (MLB)(A)(H)
5112(911) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS map changed to (561) (MLB)(A)(H)
5113(912) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS map changed to (562) (MLB)(A)(H)
5113(912) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS map changed to (562) (MLB)(A)(H)
5114(913) - MLB [MPEG4 HD] Nimiq5 72.7W TP 30 ConUS map changed to (563) (MLB)(A)(H)
5114(913) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS map changed to (563) (MLB)(A)(H)
5115(914) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map changed to (564) (MLB)(A)(H)
5115(914) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS map changed to (564) (MLB)(A)(H)
5881(890) - MLB [MPEG4 HD] Nimiq5 72.7W TP 28 ConUS map changed to (565) (MLB)(A)(H)
5881(890) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS map changed to (565) (MLB)(A)(H)
5882(891) - MLB [MPEG4 HD] Echostar16 61.5W TP 05 Conus map changed to (541) (MLB)(A)(H)
5882(891) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS map changed to (541) (MLB)(A)(H)
5883(892) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map changed to (542) (MLB)(A)(H)
5883(892) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS map changed to (542) (MLB)(A)(H)
5884(893) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map changed to (543) (MLB)(A)(H)
5884(893) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS map changed to (543) (MLB)(A)(H)
5885(894) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map changed to (544) (MLB)(A)(H)
5885(894) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS map changed to (544) (MLB)(A)(H)
5886(895) - MLB [MPEG4 HD] Nimiq5 72.7W TP 27 ConUS map changed to (545) (MLB)(A)(H)
5886(895) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS map changed to (545) (MLB)(A)(H)
5887(896) - MLB [MPEG4 HD] Echostar16 61.5W TP 05 Conus map changed to (546) (MLB)(A)(H)
5887(896) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS map changed to (546) (MLB)(A)(H)
5888(897) - MLB [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS map changed to (547) (MLB)(A)(H)
5888(897) - MLB [MPEG4 HD] Ciel-2 129W TP 27 ConUS map changed to (547) (MLB)(A)(H)
5889(898) - MLB [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS map changed to (548) (MLB)(A)(H)
5889(898) - MLB [MPEG4 HD] Ciel-2 129W TP 27 ConUS map changed to (548) (MLB)(A)(H)
5890(899) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS map changed to (549) (MLB)(A)(H)
5890(899) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS map changed to (549) (MLB)(A)(H)
Transponder Changes:
Nimiq5 72.7W TP 25 ConUS (21.500 8PSK 2/3) removed.
Channels in the system: 9640
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated
2/06/2017 07:12 - Uplink Report - 1 Change
2/11/2017 14:54 - Uplink Report - 22 Changes
