D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 2/25/2009 2:28pm - 84 changes
Uplink Comparison Range: 02/25/2009 01:57P - 02/25/2009 02:28P
Channel Additions:
5151(3) - WISC [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 4 beam (NA)(Madison, WI-CBS)
5161(12) - WKRC [MPEG4 HD] added to EchoStar8 77W TP 04 ConUS beam (NA)(Cincinnati, OH-CBS)
5170(24) - WPTY [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 9 beam (NA)(Memphis, TN-ABC)
5223(44) - KWKT [MPEG4 HD] added to Echostar12 61.5W TP 11 Area 3 beam (NA)(Waco, TX-FOX)
5250(40) - KHBS [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 37 (NA)(Fort Smith, AR-ABC)
5250(8) - KJCT [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 19 (NA)(Grand Junction, CO-ABC)
5251(5) - KFSM [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 37 (NA)(Fort Smith, AR-CBS)
5251(5) - KREX [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 19 (NA)(Grand Junction, CO-CBS)
5252(11) - KKCO [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 19 (NA)(Grand Junction, CO-NBC)
5252(51) - KNWA [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 37 (NA)(Rogers, AR-NBC)
5253(24) - KFTA [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 37 (NA)(Fort Smith, AR-NBC)
5253(4) - KFQX [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 19 (NA)(Grand Junction, CO-FOX)
6132 - HTBA [MPEG2 SD] added to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
6133 - RTVI [MPEG2 SD] added to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
7524(26) - KTEND [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 21 (NA)(Ada, OK-NBC)
7524(26) - KTEND [MPEG4 SD] added to Echostar12 61.5W TP 01 Area 3 beam (NA)(Ada, OK-NBC)
8386(14) - KETH [MPEG4 SD] added to Echostar12 61.5W TP 13 Area 3 beam (NA)(Houston, TX-TRIN)
9646(99) - ASCC [MPEG2 SD] added to EchoStar11 110W TP 10 ConUS beam (NA)
36853 - DNL12 [143] added to EchoStar9 121W TP 21 ConUS beam (A)
Channel Removals:
374 - SMITH (A) removed from Ciel-2 129W TP 17 ConUS beam
374 - SMITH (A) removed from EchoStar3 61.5W TP 32 ConUS beam
539 - HDPPV (A) removed from Echostar6 72.7W TP 17 ConUS beam
548 - HDPPV (A) removed from EchoStar8 77W TP 32 ConUS beam
620 - GEOTV (A) (H) removed from EchoStar3 61.5W TP 18 ConUS beam
4274 - SMITH (A) (H) removed from Ciel-2 129W TP 17 ConUS beam
4274 - SMITH (A) (H) removed from EchoStar3 61.5W TP 32 ConUS beam
5371 - SMITH (A) (H) removed from Ciel-2 129W TP 17 ConUS beam
5371 - SMITH (A) (H) removed from EchoStar3 61.5W TP 32 ConUS beam
5995 - INFO (NA) removed from EchoStar11 110W TP 02 ConUS beam
5998 - INFO4 (NA) removed from EchoStar11 110W TP 21 ConUS beam
5999 - INFO5 (NA) removed from EchoStar11 110W TP 21 ConUS beam
6102 - GEOTV (A) (H) removed from EchoStar3 61.5W TP 29 ConUS beam
7026 - KIDZ (A) (H) removed from EchoStar1 148W TP 31 ConUS beam(Abilene, TX-N/A)
7027 - KPCB (A) (H) removed from EchoStar1 148W TP 31 ConUS beam(Snyder, TX-N/A)
7028 - KTES (A) (H) removed from EchoStar1 148W TP 31 ConUS beam
8504 - WOCK (A) (H) removed from EchoStar10 110W TP 31 Spotbeam 19 (Chicago, IL-N/A)
8504 - WOCK (A) (H) removed from Echostar12 61.5W TP 09 Area 4 beam(Chicago, IL-N/A)
9450 - INFO5 (NA) removed from EchoStar11 110W TP 02 ConUS beam
Channel Moves:
539 - HDPPV [MPEG4 HD] moved from EchoStar11 110W TP 13 ConUS beam to Ciel-2 129W TP 31 ConUS beam (A)
539 - HDPPV [MPEG4 HD] moved from EchoStar11 110W TP 13 ConUS beam to EchoStar8 77W TP 32 ConUS beam (A)
548 - HDPPV [MPEG4 HD] moved from Ciel-2 129W TP 31 ConUS beam to EchoStar11 110W TP 13 ConUS beam (A)
548 - HDPPV [MPEG4 HD] moved from Ciel-2 129W TP 31 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A)
592 - RTVI [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
594 - HTBA [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
5180 - WRTV [MPEG4 HD] moved from Ciel-2 129W TP 05 Spotbeam 24 to EchoStar5 129W TP 05 ConUS beam (NA)(Indianapolis, IN-ABC)
5181 - WISH [MPEG4 HD] moved from Ciel-2 129W TP 05 Spotbeam 24 to EchoStar5 129W TP 05 ConUS beam (NA)(Indianapolis, IN-CBS)
5182 - WTHR [MPEG4 HD] moved from Ciel-2 129W TP 05 Spotbeam 24 to EchoStar5 129W TP 05 ConUS beam (NA)(Indianapolis, IN-NBC)
5183 - WXIN [MPEG4 HD] moved from Ciel-2 129W TP 05 Spotbeam 24 to EchoStar5 129W TP 05 ConUS beam (NA)(Indianapolis, IN-FOX)
8042 - WBRZ [MPEG2 SD] moved from EchoStar11 110W TP 02 ConUS beam to EchoStar10 110W TP 25 Spotbeam 12 (NA)(Baton Rouge, LA-ABC)
Channel Package Flag Changes:
128 - WE [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed package flags (A)
128 - WE [MPEG4 SD] - Echostar6 72.7W TP 15 ConUS beam changed package flags (A)
151 - VS. [MPEG2 SD] - EchoStar11 110W TP 01 ConUS beam changed package flags (A)
151 - VS. [MPEG4 SD] - Echostar6 72.7W TP 05 ConUS beam changed package flags (A)
174 - DISXD [MPEG2 SD] - EchoStar7 119W TP 06 ConUS beam changed package flags (A)
174 - DISXD [MPEG4 SD] - Echostar6 72.7W TP 05 ConUS beam changed package flags (A)
191 - G4 [MPEG2 SD] - EchoStar11 110W TP 05 ConUS beam changed package flags (A)
191 - G4 [MPEG4 SD] - Echostar6 72.7W TP 15 ConUS beam changed package flags (A)
5250(19) - WKPT [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 31 changed to Available (H)(Kingsport, TN-ABC)
5250(4) - WCIV [MPEG4 HD] - Ciel-2 129W TP 09 Spotbeam 44 changed to Available (H)(Charleston, SC-ABC)
5250(7) - KVIA [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 46 changed to Available (H)(El Paso, TX-ABC)
5251(11) - WJHL [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 31 changed to Available (H)(Johnson City, TN-CBS)
5251(4) - KDBC [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 46 changed to Available (H)(El Paso, TX-CBS)
5251(5) - WCSC [MPEG4 HD] - Ciel-2 129W TP 09 Spotbeam 44 changed to Available (H)(Charleston, SC-CBS)
5252(2) - WCBD [MPEG4 HD] - Ciel-2 129W TP 09 Spotbeam 44 changed to Available (H)(Charleston, SC-NBC)
5252(5) - WCYB [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 31 changed to Available (H)(Bristol, VA-NBC)
5252(9) - KTSM [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 46 changed to Available (H)(El Paso, TX-NBC)
5253(14) - KFOX [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 46 changed to Available (H)(El Paso, TX-FOX)
5253(24) - WTAT [MPEG4 HD] - Ciel-2 129W TP 09 Spotbeam 44 changed to Available (H)(Charleston, SC-FOX)
5253(39) - WEMT [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 31 changed to Available (H)(Greeneville, TN-FOX)
5260(22) - WJCL [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 44 changed to Available (H)(Savannah, GA-ABC)
5260(27) - WTXL [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 51 changed to Available (H)(Tallahassee, FL-ABC)
5261(11) - WTOC [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 44 changed to Available (H)(Savannah, GA-CBS)
5261(6) - WCTV [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 51 changed to Available (H)(Thomasville, GA-CBS)
5262(3) - WSAV [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 44 changed to Available (H)(Savannah, GA-NBC)
5262(40) - WTWC [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 51 changed to Available (H)(Tallahassee, FL-NBC)
5263(28) - WTGS [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 44 changed to Available (H)(Hardeeville, SC-FOX)
5263(49) - WTLH [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 51 changed to Available (H)(Bainbridge, GA-FOX)
6506(23) - KOKI [MPEG4 HD] - EchoStar7 119W TP 01 Central Plains beam changed to Available (H)(Tulsa, OK-FOX)
8523(47) - WOAC [MPEG2 SD] - EchoStar10 110W TP 31 Spotbeam 09 changed to Available (H)(Canton, OH-N/A)
8523(47) - WOAC [MPEG4 SD] - Echostar12 61.5W TP 01 Area 4 beam changed to Available (H)(Canton, OH-N/A)
9449(174) - DISXD [MPEG4 HD] - Ciel-2 129W TP 26 ConUS beam changed package flags (A)
9449(174) - DISXD [MPEG4 HD] - EchoStar3 61.5W TP 25 ConUS beam changed package flags (A)
9466(151) - VS. [MPEG4 HD] - Ciel-2 129W TP 29 ConUS beam changed package flags (A)
9466(151) - VS. [MPEG4 HD] - EchoStar3 61.5W TP 16 ConUS beam changed package flags (A)
Channels in the system: 6497
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Additions:
Channel Removals:
Channel Moves:
