2 622's & 2 SD recievers | SatelliteGuys.US
chicagofilms
329
I was supposed to have my 2nd 622 installed today after 2 no-shows by the installer. Then he comes and did not install it. I was told it was because of the switch I have.
Is it not possible to connect 2 622's, a 508 & a 301? to a DPP44?
If not, what switch do you need?
Yes, a DPP44 will work if each 622 uses a separator and the other 2 use single cables.
Now, if you want to add OTA to each receiver it will get messier with a 4-way and 2 diplexors per leg.
-Ken
That's what I thought. After deciphering the installer's broken English, I think he forgot the separator. I knew I should have been here, but he didn't show up last Wednesday when I was home and then didn't show up again Saturday when I was home.
Dish Home
Who has better HD quality?
