D
DigiSAT Uplink Report
Guest
The first automated Uplink Report with click-able spotbeam maps. A big thanks to nelson61 for providing the data to create the maps that made this all possible!
SatelliteGuys.US DishNetwork Uplink Activity Report - 2/9/2009 9:31am - 35 changes
Uplink Comparison Range: 02/09/2009 01:37A - 02/09/2009 02:12A
Channel Removals:
6800 - UP4 (NA) removed from Ciel-2 129W TP 15 Spotbeam ??
6801 - UPSD (NA) removed from Ciel-2 129W TP 15 Spotbeam ??
Channel Moves:
6312 - WLS [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6313 - WBBM [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6314 - WMAQ [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6315 - WFLD [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6316 - WGN9 [MPEG4 HD] moved from EchoStar5 129W TP 12 ConUS beam to Ciel-2 129W TP 09 Spotbeam 22 (A) (H)(Chicago, IL)
6347 - KSTP [MPEG4 HD] moved from EchoStar5 129W TP 09 ConUS beam to Ciel-2 129W TP 13 Spotbeam 14 (A) (H)(St. Paul, MN)
6348 - WCCO [MPEG4 HD] moved from EchoStar5 129W TP 09 ConUS beam to Ciel-2 129W TP 13 Spotbeam 14 (A) (H)(Minneapolis, MN)
6349 - KARE [MPEG4 HD] moved from EchoStar5 129W TP 09 ConUS beam to Ciel-2 129W TP 13 Spotbeam 14 (A) (H)(Minneapolis, MN)
6350 - KMSP [MPEG4 HD] moved from EchoStar5 129W TP 09 ConUS beam to Ciel-2 129W TP 13 Spotbeam 14 (A) (H)(Minneapolis, MN)
7315 - WCHS [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Charleston, WV)
7316 - WOWK [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Huntington, WV)
7317 - WSAZ [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Huntington, WV)
7318 - WVAH [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Charleston, WV)
7319 - WQCW [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Portsmouth, OH)
7321 - WPBY [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Huntington, WV)
7322 - WOUB [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Athens, OH)
7324 - WKAS [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Ashland, KY)
7325 - WPBO [MPEG2 SD] moved from Ciel-2 129W TP 21 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Portsmouth, OH)
7860 - KSWO [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Lawton, OK)
7861 - KAUZ [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Wichita Falls, TX)
7862 - KFDX [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Wichita Falls, TX)
7863 - KJTL [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Wichita Falls, TX)
7865 - KKTM [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 13 Spotbeam 36 (A) (H)(Altus, OK)
7910 - WBOYD [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Clarksburg, WV)
7911 - WDTV [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Weston, WV)
7912 - WBOY [MPEG2 SD] moved from EchoStar5 129W TP 16 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Clarksburg, WV)
7913 - WVFX [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Clarksburg, WV)
7915 - WNPB [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 09 Spotbeam 31 (A) (H)(Morgantown, WV)
7929 - WVAW [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
7930 - WCAV [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
7931 - WVIR [MPEG2 SD] moved from Ciel-2 129W TP 32 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
7932 - WAHU [MPEG2 SD] moved from Ciel-2 129W TP 21 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
7933 - WHTJ [MPEG2 SD] moved from Ciel-2 129W TP 21 ConUS beam to Ciel-2 129W TP 15 Spotbeam 39 (A) (H)(Charlottesville, VA)
Channels in the system: 6505
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Removals:
Channel Moves:
