2 dual receiver dish network problems | SatelliteGuys.US
rhall79079
3
I have a new dishnetwork satellite. i hav one dish, 2 receivers both dual one has dvr. the receiver with dvr is not working properly. i keep getting the acquiring satellite the other 2 tv's that are hooked together work fine
what kind of problem can this be Dish has sent me a new dvr receiver but getting same results
Schedule a service call and get them out to fix it.:)
Does it cycle through on the progress, or does it stay blank?
Have you done a check switch test? If so, what is the result?
How is your antenna connected? Dish1000? with, or without a switch? What kind of LNB are you using? Is there a Seperator involved?
Dish network has come out and changed a diplexer outside, this worked for a couple of days then the same problems came out again. the other receiver is working fine. My dish has a 110 and 119 on one side and another on the otherside but there is no cables hooked up to that. this is getting frustating because the other receiver is working fine
Somewhere a connector is not getting a good connection,(to the sheild I would guess).
Another technician came out and changed the lnb and a diplexer inside still same problems i'm tired of calling dish
DirecTV-only MLB package?
Lost local HD satellite channels only
