2 Hoppers w/sling and Dishanywhere | SatelliteGuys.US
Tvland1
609
679
ohio
Recently added a Hopper w/sling to my RV account along with a 222k,211k and wally..Only the hopper and 211k are currently active.I have 1 fire stick and one firetv that only show the hopper on the receiver list but my android boxes and phone shows both receivers..I can watch any number of devices with the limited channels on livestream in guide using the 211k receiver choice and all channels including OTA with the hopper on every device one at a time..I have another new hopper w/sling I'm wanting to add but I not sure if I will have a choice of receivers on the fire stick or the firetv? Will using 2 hoppers/w sling give me 2 receiver choices on Dishanywhere fire stick app? Basically have 2 hoppers and 2 different anywhere streams going on at same time..
I have 2 Hopper3 receivers and both can be accessed on the Amazon Fire Stick.
To pick which Hopper to access do the following:
1) Select Dish Anywhere on the Fire Stick
2) On the top menu scroll over to settings on the far right
3) Scroll down to General and select Receivers on the Right
4) Both of your Hopper receivers should be listed with a check Mark on the one that is active
5) You can change which Hopper is selected by selecting the one you want.
I hope this helps.
Thanks for the reply.. Currently both fire stick and firetv show the hopper in the receiver list but not the 211k.. However when I use the android phone or boxes they show the hopper and the 211k for receiver choices.. I'm thinking it's probably because the 211k isn't hooked up to the internet and the fire sticks only show the internet connected receiver?
211K is not sling enabled.
I understand that but I can choose the 211 receiver in the receiver list on my phone and android boxes and still get around 35 livestream channels.. I've always been able to do that.. Just curious why it doesn't show up on the fire sticks.. Guess like you said that they need to be sling receiver for the fire sticks
internal resets and apps crashing
How to pair a 21.0 remote to a Hopper Duo
