have a question involving two pico macom tsms-5/16 14v/18v multiswitches to a triple satellite quad output switchable xKu LNBF Linear. Polarization: vertical 10.5-14.2V Horizontal: 15.2-21.0V. one side of the sat lnb (Sat A) says there are 0 khz. on the other side (sat B) says 22khz. now on the back of the multiswitch there is 18v 0khz 18v 22khz, 14v 0khz 14v 22khz and antenna input. i used the 14v 0khz and 14V 22khz inputs on back of multiswitches. so there are four wires going to the lnb, 2 from each switch. i went to test voltage at lnb end all say around thirteen eight so i unhooked the cables from multiswitch on the 0khz inputs tested for power, attached the energized 22khz to the lnb Sat B side and 0khz to sat A. I cannot get a signal have i gotten something wrong? This is provided by shaw By the way.
