211k and EHD | SatelliteGuys.US
211k and EHD
fmj77
302
358
Western North Carolina
I just activated a 211k and noticed that everytime I connect or disconnect my external hard drive it requires a reboot of the receiver and a re-download of the program guide. Is this normal? Is the best course of action just to leave the EHD plugged in to the receiver 24/7?
I never had a 211 to try this. But to my knowledge that is normal. For one thing, it downloads a much larger 9-day guide which is stored on disk.
That is what I would recommend.
Waaay back when I got my first 211 I tried unplugging the hard drive while it was still turned on and it corrupted the OS on the hard drive. I had to reconnect it to a PC, wipe the partitions, rebuild the Windows partitions, then it would accept the drive to reformat to its liking. So, I never just unplugged the drive after that. Always turned the 211 off before disconnecting. Dish may have a more sophisticated OS on there now that can tolerate live disconnects.
IIRC, the reason it must reboot after disconnecting the hard drive is because the OS that knows how to record is actually on the hard drive and without the hard drive it reverts to an on-chip OS that is much simpler. This is also part of the reason for the incompatibility between the EHD's from the Hopper/722/622 and the 211/411.
The menu for the 211k has an option under 'My DVR" to safely remove the DVR.
Name the #1 reason you're "moved"...
