211k EHD questions | SatelliteGuys.US
211k EHD questions
yaz96
Baby, It's Cold Outside
12,829
Front Range, Colorado
Can you use multiple drives (swapping) with the 211?
And to verify - Is it only $7 per month for the 211 as a second receiver?
Do you think you'll ever be able to use 622 EHD's with the 211 or vice-versa?
I'm thinking of going this way instead of a 612. Anyone with a good reason not to?
Thanks!
Should a 311 receiver loose authorization when it is powered off?
Is Dish HD 1080p?
