211k remote | SatelliteGuys.US
211k remote
larryf
203
Texas
what would be the easiest way to control a 211k from a second room. I plan on running a component cable from a bedroom to an adjoining seldom used bedroom and would like to be able to control the 211 from both rooms.
It doesn't look like they're on mydish.com, but agents can order them.
I am known as a Dish Defender, but in this case I can't. Solid Signal and even Amazon will sell them if you don't "avail the SALE". Anyway, you might want to "send" this up the chain.
I think it's another situation where someone may order this without need since a lot of our receivers don't require this to use a UHF remote. I'll forward the feedback though.
Dish magazine on line
Putting service on hold ?
