22khz switch problem? | SatelliteGuys.US
SatAdam
261
I am toying with a 22khz switch, Chiefta brand. It seems to hang when swapping back and forth and I have to turn off the reciever and back on for everything to get kosher.
Is this a bad switch? or does my reciever not know how to properly handle the switch?
I assume you have it set up properly in your reicevers setup
dish with 22k side needs to be set to "22k" or "ON"...the other is set to off or "0K"
I have an unknown cheapo ebay LNB, I have it set up as a standard, 10700 but I just got a Sadoun standard LNB to replace it with. Do you think that is what's causing my problem??
I also got an Invacom quad today as well, that thing is HUGE! Now I await my motor. ;)
edit: The switch says "Toneburst" on it, does that change any way the switch operates?
If it is a Universal that you had, you can't use it with a 22k switch since the LNB has one built in. It will work with standard LNB's
LO for standard is 10750 :)
If you are using the Standard Sadoun LNBF that will not be the problem. I am sure its just a typo but the L.O. should be 10750
Same with the linear side of your NEW Invacom (10750)
PSB...he has a no name LNB and is changing it to a Sadoun ;)
I have a feeling the no name lNB is a Universal
I'll change it in the morning when I get home... and I'll let you guys know :)
Thanks!
And yes, it was a typo, 10750 :) (Well, I typed what my mind was thinking, but my setup on the dish was right)
Alrighty then.. I replaced the junk LNB with the Invacom
WHAT A DIFFERENCE!!!
I gained about 10% signal strength and no longer have that switching problem
I wonder if the LNB was floating freq.?
One definately needs quality equipment.
Now, when that motor gets here, I'm gonna have fun! ;)
Plz help the poor with PVV
Strange Diseqc signal loss problem...
