H halsan40 SatelliteGuys Guru Original poster Jan 6, 2006 124 0 Palm Bay, Fl Jan 12, 2007 #1 Sorry for the stupid question, But is the show 24 availiable on Dish? I can't find it.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,369 14,794 Mankato, MN Jan 12, 2007 #2 what do you mean? Its on your local Fox affiliate so if you have access to Fox then yes you can see 24
H halsan40 SatelliteGuys Guru Original poster Jan 6, 2006 124 0 Palm Bay, Fl Jan 12, 2007 #3 Iceberg said: what do you mean? Its on your local Fox affiliate so if you have access to Fox then yes you can see 24 Click to expand... Thanks Iceberg, I have locals SD but I couldn't find it. I will look again. I just couldn't find the Fox channel. Thanks again.
S SmityWhity SatelliteGuys Pro Jun 8, 2006 1,246 0 Denver, CO Jan 12, 2007 #4 You must be getting ready for the new season that starts this Sunday night! The first show Sunday will be 2 hours long, as well as the 2nd show on Monday night.
FredC SatelliteGuys Family Nov 15, 2006 105 0 Chicago, IL Jan 12, 2007 #5 Be sure to check which favoriate list your looking under! Perhaps FOX got zapped off one.
