T Tac Supporting Founder Original poster Supporting Founder Dec 12, 2003 299 5 Erie, PA Dec 19, 2003 #1 Is there any way to use a D* dish that is disconnected, as a 2nd dish pointing @ 61.5 to receive E* programming.?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,372 14,808 Mankato, MN Dec 19, 2003 #2 If its a 18" dish with no switches built in (like the phase iii does), yes you can. I think you can use the LNB, you would have to get a SW21 switch.
sclaws Supporting Founder Supporting Founder Sep 8, 2003 249 4 Aurora, IL Dec 19, 2003 #3 It should work for legacy stuff, but if you need to upgrade your LNBF to DishPro I don't believe the LNBF will fit.
