3/17/2010 1:52pm - Uplink Activity Report - 25 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/17/2010 3:26pm - 25 changes
Uplink Comparison Range: 03/17/2010 01:32P - 03/17/2010 01:51P
Channel Additions:
7569(7) - KJCTD [MPEG2 SD] added to EchoStar10 110W TP 26 Spotbeam 34 (NA)(Grand Junction, CO-N/A)
5263(26) - KFBBD [MPEG4 HD] added to Ciel-2 129W TP 13 Spotbeam 6 (NA)(Great Falls, MT-FOX)
5273(17) - KTMFD [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 11 (NA)(Missoula, MT-FOX)
7595(17) - KVIAD [MPEG2 SD] added to EchoStar10 110W TP 29 Spotbeam 31 (NA)(El Paso, TX-N/A)
298 - MOVIE [MPEG2 SD] added to EchoStar11 110W TP 08 ConUS beam (A)
298 - MOVIE [MPEG4 SD] added to EchoStar8 77W TP 16 ConUS beam (A)
5410 - ALTUD [MPEG4 HD] added to EchoStar3 61.5W TP 30 ConUS beam (NA)
6154 - LTD17 [MPEG2 SD] added to Ciel-2 129W TP 21 ConUS beam (NA)
19211 - OTST7 [DATA] added to Anik F3 118.7W TP 13 ConUS beam (A) (H)
Channel Removals:
8985 - KXXV (A) (H) removed from Echostar12 61.5W TP 11 Spotbeam 17(Waco, TX-ABC)
298 - ONPPV (A) removed from EchoStar11 110W TP 16 ConUS beam
298 - ONPPV (A) removed from Nimiq5 72.7W TP 25 ConUS beam
19217 - OTST5 (A) (H) removed from Anik F3 118.7W TP 13 ConUS beam
Channel Moves:
9058 - WXGA [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar10 110W TP 25 Spotbeam 03 (A) (H)(Waycross, GA-PBS)
8756 - WUNC [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 14 to EchoStar10 110W TP 31 Spotbeam 05 (A) (H)(Chapel Hill, NC-PBS)
Channel Package Flag Changes:
5254(19) - KEPR [MPEG4 HD] - Ciel-2 129W TP 11 Spotbeam 5 changed to Available (H)(Pasco, WA-CBS)
608 - ITVN [MPEG2 SD] - EchoStar3 61.5W TP 29 ConUS beam changed package flags (A)
620 - HUMTV [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed to Available
621 - GPUNJ [MPEG2 SD] - Anik F3 118.7W TP 30 ConUS beam changed to Available
623 - MSALA [MPEG2 SD] - Anik F3 118.7W TP 26 ConUS beam changed to Available
736 - ITVN [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
9531(101) - DNFYI [MPEG4 HD] - EchoStar11 110W TP 13 ConUS beam changed to Not Available
9531(101) - DNFYI [MPEG4 HD] - Nimiq5 72.7W TP 27 ConUS beam changed to Not Available
Channel Mapdown Changes:
9370 - KEPR EchoStar10 110W TP 12 Spotbeam 45 mapdown changed from 18 to 19 (A) (H)(Pasco, WA-CBS)
Channel Renames:
7854(67) - WRJM - EchoStar10 110W TP 31 Spotbeam 11 renamed to WIYC (A) (H)(Troy, AL-MY)
Channels in the system: 6866
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.03.12
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
Channel Renames:
I'm glad to see Dish finally updated WRJM to WIYC in the Montgomery area. However, it still lists it as "MY." We lost our MyNet months ago and got this country music video station instead. This one was actually not Dish's fault. Dish gave me the Superstations for no charge so I would have a MyNet affiliate. (or two)
Channel Renames:
What station is this? The affiliation and DMA location of each station is a database I maintain by hand of each station. I rely on you folks, Wikipedia, and the FCC database(location of license) to keep these up to date. If I see some missing, I update these but if they are not missing I assume they are still correct.
Also, on the station renames, currently the uplink tool reports the station location/affiliation on the name on the left. If you click on the spotbeam link for that station on the report, you'll notice I do not have an entry from WIYC. I'll update this station as soon I as get some info on this one.
On another note, the next revision of the uplink report tool will report the sub channel's location such as KJCTD as the master record of KJCT is I do not have a listing of KJCTD itself.
So, if you see incorrect and/or missing information your stations on the reports and/or TheList please PM me with the info and I will update it.
"What station is this? The affiliation and DMA location of each station is a database I maintain by hand of each station. I rely on you folks, Wikipedia, and the FCC database(location of license) to keep these up to date. If I see some missing, I update these but if they are not missing I assume they are still correct. "
WIYC-48(The Country Network)
4266 Lomac Street
Montgomery, Alabama 36106
(877) 655-2351
TCNCountry.com
Channels
48-1 WIYC(TCN) (channel 67 on Dish)
Source: Montgomery TV and Radio
4266 Lomac Street
(877) 655-2351
TCNCountry.com
Channels
Thanks for the update. Looks like they are still licensed for Troy, AL
TV Query Results -- Video Division (FCC) USA
Wonder what the point of moving PBS from Georgia and NC from 119 to 110 was?
Probably prepping for E14 since they'll have to shift programming on the beams when E7 to E14 conversion is done. If you can move stuff off of 119's spotbeams to 110 that's just less to deal with.
One of the reasons they want pure arc installs... as they could shift programming off 119 to 129 since some areas have room too. But of course it wasn't until recently that SD installs also got 129 too on WA.
What was on the DNFYI HD channel? I noticed it last night, and it seems today they took it down.
Everytime I checked it just gave me a message saying that the this special event is not available for purchase so I am glad they took it off since there was nothing on there. If they would only really use the channel and put the Charlie and Tech Chats in HD but they won't.
its licensed to Pasco and is a sister station to Yakima KIMA
They are both in the Yakima DMA
Interesting... I punched in a Yakima address in dishnetwork's local channel verification site and indeed they have two CBS's. Two CBS HD channels in the DMA. Nice!
Sort of like Grand Rapids, MI - 2 ABC stations in HD
WZZM/13 serves the north part of the market and I would conside the primary affil
WOTV/41 serves the south part of the market
Interestingly enough, WOOD/8, the NBC station, owns WOTV/41... That's probably how WOTV ended up on sat in HD...
Jim
D
3/17/2010 6:28am - Uplink Activity Report - 10 changes
D
3/20/2010 6:27am - Uplink Activity Report - 2 changes
