3/28/2017 07:17 - Uplink Report - 101 Changes | SatelliteGuys.US
  • Thread starter Thread starter Uplink PC
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 3/28/2017 07:17 - 101 Changes
Uplink Comparison Range: 3/28/2017 06:54 - 3/28/2017 07:17 (PST)
Tier Changed:
541 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS moved to Echostar16 61.5W TP 11 Conus , changed to (MLB)(A)(H)
541 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS moved to EchoStar14 119W TP 17 ConUS , changed to (MLB)(A)(H)
542 - MLB [MPEG2 SD] EchoStar14 119W TP 16 ConUS moved to EchoStar14 119W TP 17 ConUS , changed to (MLB)(A)(H)
542 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS moved to Nimiq5 72.7W TP 09 ConUS , changed to (MLB)(A)(H)
543 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 18 ConUS , changed to (MLB)(A)(H)
543 - MLB [MPEG4 SD] Echostar16 61.5W TP 11 Conus moved to Nimiq5 72.7W TP 05 ConUS , changed to (MLB)(A)(H)
544 - MLB [MPEG2 SD] EchoStar14 119W TP 10 ConUS changed to (MLB)(A)(H)
544 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS changed to (MLB)(A)(H)
545 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS changed to (MLB)(A)(H)
545 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS moved to Nimiq5 72.7W TP 07 ConUS , changed to (MLB)(A)(H)
546 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 18 ConUS , changed to (MLB)(A)(H)
546 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 05 ConUS , changed to (MLB)(A)(H)
547 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS moved to Nimiq5 72.7W TP 29 ConUS , changed to (MLB)(A)(H)
547 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS moved to EchoStar11 110W TP 24 ConUS , changed to (MLB)(A)(H)
548 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS changed to (MLB)(A)(H)
548 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS changed to (MLB)(A)(H)
549 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS moved to EchoStar14 119W TP 18 ConUS , changed to (MLB)(A)(H)
549 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS moved to Nimiq5 72.7W TP 09 ConUS , changed to (MLB)(A)(H)
550 - MLB [MPEG2 SD] EchoStar11 110W TP 09 ConUS moved to EchoStar14 119W TP 10 ConUS , changed to (MLB)(A)(H)
550 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS moved to Nimiq5 72.7W TP 07 ConUS , changed to (MLB)(A)(H)
551 - MLB [MPEG2 SD] EchoStar14 119W TP 10 ConUS moved to EchoStar14 119W TP 18 ConUS , changed to (MLB)(A)(H)
551 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 05 ConUS , changed to (MLB)(A)(H)
552 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to (MLB)(A)(H)
552 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS changed to (MLB)(A)(H)
553 - MLB [MPEG2 SD] EchoStar14 119W TP 16 ConUS changed to (MLB)(A)(H)
553 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS changed to (MLB)(A)(H)
554 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS moved to Nimiq5 72.7W TP 29 ConUS , changed to (MLB)(A)(H)
554 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS moved to EchoStar11 110W TP 24 ConUS , changed to (MLB)(A)(H)
555 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS moved to EchoStar14 119W TP 16 ConUS , changed to (MLB)(A)(H)
555 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS moved to Nimiq5 72.7W TP 05 ConUS , changed to (MLB)(A)(H)
556 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS moved to EchoStar14 119W TP 16 ConUS , changed to (MLB)(A)(H)
556 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS moved to Nimiq5 72.7W TP 07 ConUS , changed to (MLB)(A)(H)
557 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS moved to EchoStar14 119W TP 18 ConUS , changed to (MLB)(A)(H)
557 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS moved to Nimiq5 72.7W TP 05 ConUS , changed to (MLB)(A)(H)
558 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS moved to Nimiq5 72.7W TP 29 ConUS , changed to (MLB)(A)(H)
558 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS moved to EchoStar11 110W TP 24 ConUS , changed to (MLB)(A)(H)
559 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS changed to (MLB)(A)(H)
559 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS moved to Nimiq5 72.7W TP 07 ConUS , changed to (MLB)(A)(H)
560 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS moved to EchoStar14 119W TP 10 ConUS , changed to (MLB)(A)(H)
560 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS moved to Nimiq5 72.7W TP 07 ConUS , changed to (MLB)(A)(H)
561 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS changed to (MLB)(A)(H)
561 - MLB [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS moved to Nimiq5 72.7W TP 05 ConUS , changed to (MLB)(A)(H)
562 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS changed to (MLB)(A)(H)
562 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 05 ConUS , changed to (MLB)(A)(H)
563 - MLB [MPEG4 SD] Nimiq5 72.7W TP 29 ConUS changed to (MLB)(A)(H)
563 - MLB [MPEG2 SD] EchoStar11 110W TP 24 ConUS changed to (MLB)(A)(H)
564 - MLB [MPEG2 SD] EchoStar14 119W TP 18 ConUS changed to (MLB)(A)(H)
564 - MLB [MPEG4 SD] Nimiq5 72.7W TP 05 ConUS changed to (MLB)(A)(H)
5101(550) - MLB [MPEG4 HD] Nimiq5 72.7W TP 26 ConUS moved to Nimiq5 72.7W TP 10 ConUS , changed to (MLB)(A)(H)
5101(550) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS moved to EchoStar11 110W TP 14 ConUS , changed to (MLB)(A)(H)
5102(551) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS moved to Nimiq5 72.7W TP 28 ConUS , changed to (MLB)(A)(H)
5102(551) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS changed to (MLB)(A)(H)
5103(552) - MLB [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS moved to Nimiq5 72.7W TP 08 ConUS , changed to (MLB)(A)(H)
5103(552) - MLB [MPEG4 HD] Ciel-2 129W TP 27 ConUS moved to Ciel-2 129W TP 25 ConUS , changed to (MLB)(A)(H)
5104(553) - MLB [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS changed to (MLB)(A)(H)
5104(553) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS changed to (MLB)(A)(H)
5105(554) - MLB [MPEG4 HD] Nimiq5 72.7W TP 28 ConUS moved to Nimiq5 72.7W TP 01 ConUS , changed to (MLB)(A)(H)
5105(554) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS moved to Ciel-2 129W TP 27 ConUS , changed to (MLB)(A)(H)
5106(555) - MLB [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS moved to Nimiq5 72.7W TP 27 ConUS , changed to (MLB)(A)(H)
5106(555) - MLB [MPEG4 HD] Ciel-2 129W TP 27 ConUS moved to EchoStar11 110W TP 14 ConUS , changed to (MLB)(A)(H)
5107(556) - MLB [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS moved to Nimiq5 72.7W TP 10 ConUS , changed to (MLB)(A)(H)
5107(556) - MLB [MPEG4 HD] Ciel-2 129W TP 19 ConUS moved to Ciel-2 129W TP 26 ConUS , changed to (MLB)(A)(H)
5108(557) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Echostar16 61.5W TP 05 Conus , changed to (MLB)(A)(H)
5108(557) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 26 ConUS , changed to (MLB)(A)(H)
5109(558) - MLB [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Nimiq5 72.7W TP 08 ConUS , changed to (MLB)(A)(H)
5109(558) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS moved to Ciel-2 129W TP 25 ConUS , changed to (MLB)(A)(H)
5110(559) - MLB [MPEG4 HD] Echostar16 61.5W TP 05 Conus changed to (MLB)(A)(H)
5110(559) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS changed to (MLB)(A)(H)
5111(560) - MLB [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS moved to Nimiq5 72.7W TP 10 ConUS , changed to (MLB)(A)(H)
5111(560) - MLB [MPEG4 HD] Ciel-2 129W TP 27 ConUS moved to EchoStar11 110W TP 14 ConUS , changed to (MLB)(A)(H)
5112(561) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS moved to Nimiq5 72.7W TP 28 ConUS , changed to (MLB)(A)(H)
5112(561) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS moved to EchoStar11 110W TP 14 ConUS , changed to (MLB)(A)(H)
5113(562) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS moved to Echostar16 61.5W TP 05 Conus , changed to (MLB)(A)(H)
5113(562) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS changed to (MLB)(A)(H)
5114(563) - MLB [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS changed to (MLB)(A)(H)
5114(563) - MLB [MPEG4 HD] Ciel-2 129W TP 27 ConUS changed to (MLB)(A)(H)
5115(564) - MLB [MPEG4 HD] Nimiq5 72.7W TP 20 ConUS changed to (MLB)(A)(H)
5115(564) - MLB [MPEG4 HD] Ciel-2 129W TP 28 ConUS changed to (MLB)(A)(H)
5882(541) - MLB [MPEG4 HD] Nimiq5 72.7W TP 30 ConUS moved to Echostar16 61.5W TP 05 Conus , changed to (MLB)(A)(H)
5882(541) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS moved to EchoStar11 110W TP 15 ConUS , changed to (MLB)(A)(H)
5883(542) - MLB [MPEG4 HD] Nimiq5 72.7W TP 27 ConUS moved to Echostar16 61.5W TP 05 Conus , changed to (MLB)(A)(H)
5883(542) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS moved to Ciel-2 129W TP 26 ConUS , changed to (MLB)(A)(H)
5884(543) - MLB [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Nimiq5 72.7W TP 20 ConUS , changed to (MLB)(A)(H)
5884(543) - MLB [MPEG4 HD] EchoStar11 110W TP 15 ConUS moved to Ciel-2 129W TP 28 ConUS , changed to (MLB)(A)(H)
5885(544) - MLB [MPEG4 HD] Nimiq5 72.7W TP 20 ConUS changed to (MLB)(A)(H)
5885(544) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS changed to (MLB)(A)(H)
5886(545) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS changed to (MLB)(A)(H)
5886(545) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS moved to Ciel-2 129W TP 26 ConUS , changed to (MLB)(A)(H)
5887(546) - MLB [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Nimiq5 72.7W TP 10 ConUS , changed to (MLB)(A)(H)
5887(546) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS moved to EchoStar11 110W TP 14 ConUS , changed to (MLB)(A)(H)
5888(547) - MLB [MPEG4 HD] Nimiq5 72.7W TP 20 ConUS changed to (MLB)(A)(H)
5888(547) - MLB [MPEG4 HD] Ciel-2 129W TP 28 ConUS changed to (MLB)(A)(H)
5889(548) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS changed to (MLB)(A)(H)
5889(548) - MLB [MPEG4 HD] EchoStar11 110W TP 14 ConUS moved to Ciel-2 129W TP 26 ConUS , changed to (MLB)(A)(H)
5890(549) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 30 ConUS , changed to (MLB)(A)(H)
5890(549) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to EchoStar11 110W TP 14 ConUS , changed to (MLB)(A)(H)
Channel Moves:
468 - SPORT [MPEG4 SD] Nimiq5 72.7W TP 09 ConUS moved to Nimiq5 72.7W TP 25 ConUS (Pay Per View Sports & Events)(A)
565 - MLB [MPEG2 SD] EchoStar14 119W TP 16 ConUS moved to EchoStar14 119W TP 18 ConUS (MLB)(A)(H)
565 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 09 ConUS (MLB)(A)(H)
5881(565) - MLB [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS moved to Nimiq5 72.7W TP 23 ConUS (MLB)(A)(H)
5881(565) - MLB [MPEG4 HD] Ciel-2 129W TP 26 ConUS moved to Ciel-2 129W TP 19 ConUS (MLB)(A)(H)
Transponder Changes:
Nimiq5 72.7W TP 25 ConUS (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 26 ConUS (21.500 8PSK 2/3) removed.
Channels in the system: 9677
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated
3/28/2017 07:32 - Uplink Report - 289 Changes
3/28/2017 07:20 - Uplink Report - 31 Changes
