jimmykce1 said:Well we had a good heavy thunderstorm here in hampton roads va and my 30inch dish experienced rain fade problems durning it.
andrzej said:In "good heavy thunderstorm" all satellite signals experience rain fade. It is only a matter of how much.
jimmykce1 said:I think voom needs to increase its broadcast signal strength.
JimP said:Did anybody bother to check the weather at the Voom uplink site?
If it was raining there too, then what you were experiencing was a combination of the two.
lostcause said:Will a 30" dish help if there's a tree in the way??
FunkyBoss said:Hey, I think you're onto something. That would be a wonderful addition to this site. 24-hour weather conditions at the Voom uplink site. Make it a sticky, so we can then tell when we're going to lose signal because of it. There can be little alerts when severe thunderstorms are rolling in.![]()
NOPE...no DIGITAL sat signal will go through trees...it may look as though its pointed into trees but its pointing over them or no dtvlostcause said:They could still increase their signal strength. dtv gets through trees just fine.
jellison1 said:NOPE...no DIGITAL sat signal will go through trees...it may look as though its pointed into trees but its pointing over them or no dtv
Limited time offer
