L Louie4 Member Original poster Oct 20, 2004 12 2 Jul 29, 2010 #1 Can the 30 second skip be entered into the HR24?? I found it for the HR20, but that doesn't work for the HR24. Thanks for any help. Louie
jdspencer SatelliteGuys Pro Oct 22, 2004 4,088 18 Binghamton, NY Jul 29, 2010 #2 When doing a keyword search, 30SLIP or 30SKIP should work fine.
wildbill129 SatelliteGuys Pro Jul 31, 2009 1,273 0 Redding, CA Jul 30, 2010 #3 It will work on the H24 and the HR24, I've done it on both of mine. Make sure you are doing a keyword search and not a smart search.
L Louie4 Member Original poster Oct 20, 2004 12 2 Jul 30, 2010 #4 How?? How do I do a keyword search?? I only found smart search. But I love the statues along the highway.
Jimbo SatelliteGuys Master Lifetime Supporter Cutting Edge Jul 14, 2005 69,869 8,222 NW Ohio - Buckeye Country Jul 30, 2010 #5 Go to Smart Search: Type : 30slip ALL then enter
