32.0 remote learning | SatelliteGuys.US
irwin
38
3
I am able to get most of the TV functions I want by the on screen method of the 922. There are a couple none of the codes will give me. Looking at the 32.0 remote it does have the side IR window on it so I am guessing if you have the right keystroke sequence you can have the remote learn some IR codes from the TV remote?
Does anyone one how to get this remote into the learn mode. The older method of holding down the TV button for 3 seconds and then hit record doesn't work on the 922 remote
The learning feature has not been activated yet. If it ever is DISH will need to download a firmware upgrade for the remote.
Program guide issue on 722k
Dish DTVPal DVR TVGoS in NoVA
