3g cellular router question | SatelliteGuys.US
Ace68
99
Snow Belt, OH
I am using a verizon 3g aircard with a cradlepoint mbr900 3g router. The wireless signal is ok, but I also have a zoom 3g wireless router that doesn't support my aircard. The zoom has outstanding wireless range, my question is:
can I use my zoom router as an access point to increase my coverage? Is it as easy as connecting the two with cat6, or is there configuration involved? Sorry if this is not the right place to post this. Any help would be great!
Ace
Did you have to configure your linksys or 3g router? Or just plug in LAN port to LAN port? Thanks for the quick reply!
