3x4 switch question | SatelliteGuys.US
3x4 switch question
WyrTwister
769
Well the switch I bought on ebay came in . It has ;
In LNBF A
In TV Antenna
In LNBF B
Out Receiver 1
Out Receiver 2
Out Receiver 3
Out Receiver 4
So , this is probably not the switch I thought it would be , but I can probably use it .
My guess is it combines all 3 of the " ins " and sends them to all 4 of the " outs " .
The next question is , how do I split out the sat signal from the antenna signal , at the receiver ? Use a sat splitter with DC power blocked on one port ? I seem to remember reading about a diplexer for something like this ?
Do I just set up LNBF A & LNBF B like a Diesqc switch in the receiver sat set-up menu ?
Thanks ,
Wyr
A simple diplexer will split the satellite and off air signals!
What you have their my friend is basically a 3x4 multiswitch, not a Diseqc switch
what this does is takes both feeds from a dual (and an antenna) and lets you run 4 receivers off it. It works for hooking 4 receivers to one satellite (like G10)
It wont work as a diseqc switch....The will work with a Diseqc switch, but not as one
At the receiver end , , if I do not set it up like a Diesqc switch , then do I need a modified channel list , like a DPishPro ?
Modified ini files for the PCI DVB-S cards ?
Thanks ,
Wyr
getting tired of this!
Woohoo, finally got my HD / DVB-S setup working!
