4/15/2009 1:38pm - Uplink Activity Report - 74 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 4/15/2009 1:38pm - 74 changes
Uplink Comparison Range: 04/15/2009 01:10P - 04/15/2009 01:38P
Channel Additions:
216 - ION [MPEG2 SD] added to EchoStar7 119W TP 14 ConUS beam (A)
216 - ION [MPEG4 SD] added to Echostar6 72.7W TP 31 ConUS beam (A)
217 - IONW [MPEG2 SD] added to EchoStar7 119W TP 20 ConUS beam (NA)
5153(14) - KFJX [MPEG4 HD] added to Echostar12 61.5W TP 13 Area 8 beam (NA)(Pittsburg, KS-FOX)
5260(12) - KDRV [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam ?? (NA)(Medford, OR-ABC)
5261(10) - KTVL [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam ?? (NA)(Medford, OR-CBS)
5262(5) - KOBI [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam ?? (NA)(Medford, OR-NBC)
5263(26) - KMVU [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam ?? (NA)(Medford, OR-FOX)
5422(422) - SUN [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (A) (H)
5423(423) - FOXFL [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (A) (H)
6101 - SUNTV [MPEG2 SD] added to EchoStar1 148W TP 11 ConUS beam (A) (H)
6102 - TVCI [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (A) (H)
6103 - BLUE [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (NA)
6105 - K TV [MPEG2 SD] added to EchoStar1 148W TP 25 ConUS beam (NA)
6106 - RTVI [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (A) (H)
6107 - ANTGO [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (NA)
6109 - ANTEN [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (NA)
6110 - INTER [MPEG2 SD] added to EchoStar1 148W TP 29 ConUS beam (NA)
6111 - HTBA [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (A) (H)
6112 - RTVI+ [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (NA)
6125 - MUSIK [MPEG2 SD] added to EchoStar1 148W TP 29 ConUS beam (A) (H)
6127 - QTV [MPEG2 SD] added to EchoStar1 148W TP 29 ConUS beam (A) (H)
6128 - ERT [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (A) (H)
6131 - GLBL1 [MPEG2 SD] added to EchoStar1 148W TP 03 ConUS beam (A) (H)
6132 - ISMOV [MPEG2 SD] added to EchoStar1 148W TP 03 ConUS beam (A) (H)
6133 - ISRLI [MPEG2 SD] added to EchoStar1 148W TP 01 ConUS beam (NA)
6136 - ARYDI [MPEG2 SD] added to EchoStar1 148W TP 09 ConUS beam (A) (H)
6137 - ARYOW [MPEG2 SD] added to EchoStar1 148W TP 29 ConUS beam (NA)
6138 - GEOTV [MPEG2 SD] added to EchoStar1 148W TP 03 ConUS beam (A) (H)
6139 - INDMU [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (A) (H)
6140 - INDUS [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (A) (H)
6141 - PTV [MPEG2 SD] added to EchoStar1 148W TP 09 ConUS beam (NA)
6799(77) - HIDEF [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS beam (NA)
8025(30) - KPXN [MPEG2 SD] added to EchoStar7 119W TP 20 ConUS beam (NA)(San Bernardino, CA-N/A)
8994(50) - KBTX [MPEG2 SD] added to EchoStar7 119W TP 05 Texas beam (NA)(Bryan, TX-CBS)
8994(50) - KBTX [MPEG4 SD] added to Echostar12 61.5W TP 11 Area 3 beam (NA)(Bryan, TX-CBS)
Channel Removals:
212 - CSPN2 (A) removed from EchoStar11 110W TP 19 ConUS beam
212 - CSPN2 (A) removed from Echostar6 72.7W TP 07 ConUS beam
216 - C&T (A) removed from EchoStar11 110W TP 19 ConUS beam
216 - C&T (A) removed from EchoStar3 61.5W TP 27 ConUS beam
217 - DISH (A) removed from EchoStar11 110W TP 19 ConUS beam
217 - DISH (A) removed from Echostar12 61.5W TP 23 ConUS beam
578 - BRDGS (A) (H) removed from EchoStar1 148W TP 09 ConUS beam
578 - BRDGS (A) (H) removed from EchoStar3 61.5W TP 08 ConUS beam
911 - ANTRA (A) (H) removed from EchoStar1 148W TP 27 ConUS beam
912 - RYTHM (A) (H) removed from EchoStar1 148W TP 27 ConUS beam
6153 - LTD16 (NA) removed from EchoStar11 110W TP 19 ConUS beam
6153 - LTD16 (NA) removed from Echostar6 72.7W TP 07 ConUS beam
8174 - KXVA (A) (H) removed from Echostar12 61.5W TP 07 Area 3 beam(Abilene, TX-FOX)
Channel Moves:
592 - RTVI [MPEG2 SD] moved from EchoStar1 148W TP 07 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
594 - HTBA [MPEG2 SD] moved from EchoStar1 148W TP 07 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
595 - TVCI [MPEG2 SD] moved from EchoStar1 148W TP 07 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
603 - ERT [MPEG2 SD] moved from EchoStar1 148W TP 07 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
620 - GEOTV [MPEG2 SD] moved from EchoStar1 148W TP 03 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
621 - ARYDI [MPEG2 SD] moved from EchoStar1 148W TP 09 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
662 - QTV [MPEG2 SD] moved from EchoStar1 148W TP 29 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
663 - MUSIK [MPEG2 SD] moved from EchoStar1 148W TP 29 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
674 - INDMU [MPEG2 SD] moved from EchoStar1 148W TP 27 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
678 - INDUS [MPEG2 SD] moved from EchoStar1 148W TP 27 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
702 - GLBL1 [MPEG2 SD] moved from EchoStar1 148W TP 03 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
703 - ISMOV [MPEG2 SD] moved from EchoStar1 148W TP 03 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
Channel Package Flag Changes:
602 - PNJBI [MPEG2 SD] - Anik F3 118.7W TP 26 ConUS beam changed to Available
727 - VIDIT [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
730 - RAINW [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
775 - AGAPY [MPEG2 SD] - Anik F3 118.7W TP 19 ConUS beam changed to Available
809 - JUS [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
5150(6) - WDAY [MPEG4 HD] - Ciel-2 129W TP 09 Spotbeam 8 changed to Available (H)(Fargo, ND-ABC)
5153(23) - WPFO [MPEG4 HD] - Echostar12 61.5W TP 09 Area 6 beam changed to Available (H)(Waterville, ME-FOX)
5173(15) - KXVA [MPEG4 HD] - Echostar12 61.5W TP 07 Area 3 beam changed to Available (H)(Abilene, TX-FOX)
7048(3) - WBEP [MPEG2 SD] - Ciel-2 129W TP 06 Spotbeam 25 changed to Available (H)
8746(50) - KHBBD [MPEG2 SD] - EchoStar10 110W TP 29 Spotbeam 37 changed to Available (H)
Channel Renames:
8124 - KLDO3 - EchoStar10 110W TP 27 Spotbeam 17 renamed to KXOF (NA)(Laredo, TX-UNI)
9645(99) - LF1 - EchoStar11 110W TP 10 ConUS beam renamed to SONY (A)
9645(99) - LF1 - EchoStar8 77W TP 29 ConUS beam renamed to SONY (A)
Channels in the system: 6428
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Except for locals and maybe free previews ... I have a feeling that things are going to be pretty quiet for a while.
What are we looking at? Call me silly!
I believe those are florida RSNs... people were having issues with locals being on 129 yet RSNs were on 61.5 thus making them not have a single dish solution. This mirror allows a single dish solution for them. (if i have the channels correct)
Yes, you are correct. For instance folks in the Gainesville, FL market had their locals launched on a 129 spotbeam. Some moved their 61.5 dish over to 129 but lost their RSN's. This should solve the issue.
So it looks like ION is moving from channel 280 to 216 sometime soon and then they are adding ION West to channel 217. D* recently added ION West but it is not located next to the East feed.
For the DMA's that dish carries SD & HD locals are they doing double work in that they carry the SD and HD signals or do they down-rez the HD for the SD channels to save on bandwidth?
And if not...why not?
On the WA they have to carry the SDs and HDs since the older boxes can not receive MPEG4 signals and can not tune 8PSK signals.
Now on EA, that's a different story. They usually pull the SD version when an HD feed goes live. Not sure why they don't do this on the nationals.
Ion TV is a joke. This means Dish Network is giving us an east and west feed of a channel that plays 12-14 hours of infomercials daily. Hmm, but we can't have LOGO.
Hey in Los Angeles where we have ION OTA they started broadcasting in HD last week. So that's 12-14 hours of upconverted infomercials daily.:D
